Completed Lone Industries L5 - 4.6L Mini ITX
nubbins
34
66
The absolute ELATION from seeing this lol -
...especially after my torturous experience with OCUK 😶 it's about time we can finally be rewarded rather than punished for being canadian 😄
Looking forward to doing a little photoshoot and a 3-way comparison between the L5, HT5 and Cerberus 🤠
Lone
731
1,250
Canada
loneindustries.com
June batch is sold out. Unfortunately, there is a small delay and I won't be able to start shipping until next week. I wasn't very happy with the quality of the white powder coating on one of the two side panels used on the L5, so my manufacturer has agreed to send replacements.
  • Love
Reactions: thelaughingman
Analogue Blacksheep
850
706
My new HDPLEX 200W DC-ATX is on the way. Pretty cool they now have a UK based warehouse. Just need to wait until I can afford the Mistix, get the vent 3D printed from somewhere and find a powered USB 2.0 hub that matches the case.
Anyway in the meantime cleaned out the fans at the front;
And also added two low noise adapters as well as the fan to Sata adapter.
On that note, does anyone know of any good powered USB 2.0 hubs that matches the look of the L5?
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
3,104
4,593
46
France
guilleacoustic.wordpress.com
Got my 240W brick today. I gotta say, I have always liked the look of modern Dell adapters with their rounded look.
Everything is set to migrate from the HT5, now only waiting for the star of the show!
Nice ! What are its dimensions and model reference ? The french Dell store only shows the rectangular one, but maybe the picture is bot up-to-date.
nubbins
34
66
It seems to be on the FR Dell store but under a different product reference number. Mine is 450-AHHE while the euro version seems to be 450-AJBL. 450-AHHE is listed by Lone on the webpage I think. Both look the same, good ol' 7.4mm barrel connector, fits snug with the HDPlex's barrel adapter.
Dell Adapter 240-Watt 7.4mm Barrel with 1M Power Cord, Cus Kit | Dell USA
adaptateur CA Dell 240watts à 3 broches avec cordon d’alimentation | Dell France
Not sure if the actual product is any different, as the brick is electrically universal 100-240VAC and has a standard C14 inlet. My guess is that they just bundle a Euro power cord. It's definitely a bit more attractive-looking than the old-type 240W ones.
Edit: forgot to add, the model number is LA240PM180 on the brick.
GuilleAcoustic
LOSIAS
Jun 29, 2015
3,104
4,593
46
France
That's very weird, because the link works but if I go back to AC listing it's nowhere to be found if I filter on 200-300 wattage.
If you scroll through the full unfiltered listing, then it shows up and it's almost half the price of the rectangular one too.
Thanks a lot for the link.
Reactions: nubbins
deeeeeeeeee
25
hey @Lone , would you mind checking your emails? i have replied to the shipping notification and i havent heard back since then, hope you can take a look at it before shipping my case out, thanks!
Lone
731
1,250
Canada
loneindustries.com
Sorry, I've replied to any emails I've received, and have checked my spam. Please send me a PM here, and check your spam if you haven't already.
Analogue Blacksheep
850
706
I missed the MiSTix pre order, so while I still want to do a MiSTer build, it won't happen till later this year. I think they will be back in stock until August.
Got the HDPLEX 200W though.
Reactions: Lone
nubbins
34
66
Damn, I haven't been this excited and impatient for a package since my GMK Dolch and 9009 R2 keysets lol 😆
CPU: Ryzen 4650G
Cooler: NH-L12 Ghost S1 Edition + NF-A9
Mobo: B550I Aorus AX
RAM: 16GB 4400 Viper Steels @ DDR4-4200 16-16-16-290 1.47V
iGPU: Vega 7 @ 2275MHz 1.2V
SSD: 1TB SN550
Power: 200W HDPlex DC-ATX + 240W Dell 450-AHHE
Fans: 2 x NF-R8 redux
It would have been really nice to have vents on the top side too, can't be hotboxing 1.5V B-die like that. So I just ended up flipping the case on its head, hopefully it works out thermally. The HT5 escaped this issue because the 2 x NF-A8 were set up as exhaust in the top of the case to pull air away from the DIMMs.
Great case! Just wish there weren't so many flakes from the powdercoating everywhere. The white/black powdercoating on my Cerberus is a little smoother, but the rougher texture is also nice in its own way.
Lone
731
1,250
Canada
loneindustries.com
By request of a forum member, I've redesigned the HDPLEX 200W AC-DC PCI Card Mount into a 3D printable part (currently untested):
Reactions: GuilleAcoustic
nubbins
34
66
Comparison between similar cases, L5 vs HT5 (5.3L):
Just for giggles, L5 vs Cerberus (18.7L):
Interestingly enough, it looks big next to a case 4x its size, yet small compared to a case only 1.15x......but rest assured it feels tiny in hand compared to either one XD
Both the Cerberus and the L5 have flawless white powdercoating. Only difference is the texture, L5 is rougher. And well, the HT5 isn't metal.
August
124
208
Oregon
gusmiller.com
Had my workstation opened up to diagnose some bad RAM (eventually realized this is what was making the OpenCore installation unstable), and figured I'd shorten up the HDPlex cables a bit.
I didn't have any male ATX pins, so I could only modify the inlet section (fine, as it was the longer of the two). Made a totally new EPS connector—and I'm glad I did, because the double crimps on the DC-ATX 4-pin end were pretty bad (the pins didn't cover or grip the insulation at all).
Ended up putting in a new SSD (WD SN750), and installing macOS Big Sur. Humming along just fine, but waiting on Corsair to respond to an RMA for the bad DIMM.
inwave
What is the diameter of the DC input hole on the back of the case? Does it support 5.5x2.5mm DC input jack with screws? I browsed the discussion and find that we can use 7.4x5.0mm DC input jack from HDPLEX, but I wonder if we can use 5.5x2.5mm with smaller diameter (11mm).
