4,796
I registered to get the latest update. I have few questions. Is there a pre-order list or is it just buy when it's released? I saw previous post stating that it will go into production sometime this month or January, is this still true?
Welcome to the forum!
General production still has no ETA. There's the mailing list but general production will be first come first serve: kimeraindustries.com/subscribe
I have to pre-order the M1 soon, so I'd like to know if it's worth holding out for this case, or if the developers have just abandoned the project?
Also welcome!
We're still working on production but it's just taking longer than planned.
How much do you think the case will "retail" for once it's in production. I'm just curious at how big of a price difference the $500 will be. I'm guessing this case is going to be a $250-300 case at retail.
We're still aiming for $250 for general production.
nemesis429
27
Will the ATX version be out at the same time, I saw somewhere that you was looking at doing an ATX version basically the same design with just couple extra slots?
Reactions: VegetableStu
4,796
Yes, Cerberus-X is Cerberus extended in height to add 3 more slots for ATX motherboard support. An issue though is since the mobo standoffs are fixed in place using a microATX motherboard in Cerberus-X isn't ideal since several standoff locations will be missing on a mATX board.
It will be released alongside Cerberus.
3lfk1ng
919
1,718
Santa Barbara
www.reihengaming.com
Excellent news!
I like how the Cerberus-X is being intentionally designed so that it will never appear in the space inefficiency thread.
"You cannot put an mATX mobo in this ATX case. If you want an mATX mobo, get the mATX case!"
4,796
That is BIG news, I thought you were going to release them separately.
Yes, I thought so too. Damn, decisions, decisions. Oh no wait I was already gunning for the ATX version a while ago :D
Haha, I thought I had already mentioned they'd release together.
It wasn't really intentional, if the standoffs could be removeable to comply with the mATX spec without making the case bigger I'd do that.
Pyrath
59
82
So roughly 6cm increase in height vs the base Cerberus?
Apologies if I've missed the posting of specific dimension changes for the Cerberus-X
4,796
Yup, a PCI slot is 20.32mm tall and there's 3 more so a ~60mm increase.
Anthony
79
36
Cincinnati
Well now that both models are being released at the same time, I may just have to redesign my build for ATX since the MATX boards are still suffering from stagnant development. I doubt that I'll be using the extra PCI slots though. Would there be more room available for watercooling on the bottom with the motherboard in place? I'll still stick to those lovely aluminum fans I found that are 25mm; a thicker rad on the bottom case would be more than adequate to cool a single gpu and cpu.
4,796
With an ATX motherboard in Cerberus-X, there are the same mobo clearance issues with thick rads as with a mATX board in Cerberus. So a thick rad could interfere with the front panel headers for USB 2.0, audio, front IO, etc.
A mATX board in Cerberus-X would fix that, but as mentioned, the standoffs are fixed in place so I wouldn't really recommend it.
How much volume does that add?
Volume of Cerberus-X is about 22L.
4,796
It's literally Cerberus but a bit taller so I haven't made any renders of it. From the outside it just looks like someone resized a picture of Cerberus and forgot to keep the height and width scaled the same amount.
LukeD
529
1,338
Sydney, Australia
LOL ! That's pretty funny.
Do you think you'll use that extra space for other features ?
E.g. if someone wants to mount an mATX board in it and add a whole bunch of water cooling ? ;)
VegetableStu
1,949
2,619
Think Aibo already mentioned that the CX doesn't mount mATX boards many times ._.
6,126
5,032
Belgium
The issue is this:
The holes B (2nd on top) R or S (2nd and 3rd in the middle) are only designed for mATX. Aibohphobia chose non-removable standoffs and these would cause short circuits on an ATX motherboard. But an mATX motherboard would still be able to be fastened to the C, F, H, J, L and M standoffs, just the bottom two (bottom PCIe slots) would not have any structural support.
As LukeD says, this doesn't mean it's not possible or fixable, by the user.
Reactions: SeeFiFo and LukeD
