Great!
Sorry, I just have a few more questions if that's okay..
- On the listing of the M2427 on your site, you have the option of adding short cables - are these just the regular stock cables that come with SF* power supplies?
- In the video on the listing, you connect a SATA power connector to a header on the M2427 - is this just so you don't have to connect SATA power cables to your PSU or does it serve another purpose? Is this cable included?
- You mention on the listing 'Platinum version requires additional wire connected to GPU power connector ' - does this mean I need to plugin an extra cable into the PCI power connector of the PSU? Not too clear on this
- When choosing between plat/gold power supplies - it seems that there would be more cables to manage for platinum. Do you recommend people stick to gold for ease of use?
Sorry again for the tonnes of questions - I'm currently planning out some components for a Sliger SM560 build and happened upon your 24pin replacement which seems ideal for cable management.
