I'm running Meanwell 200w+Pico160XT with a 1050ti and 2400g CPU with no issues even during all day LAN parties.@Thehack I'm considering pairing a 1050ti or 1650 with a Ryzen 1600 and RPS 200w unit I have. Have you had any issues with powering such a setup with it? I know maxing out the CPU and GPU together would be pushing it but under gaming type loads I feel it should be good if not a little tight on power budget.
Thoughts?
Any idea when the M2427 for the Corsair Platinum will be back in stock please ? Looking to order one along some SATA, cpu and GPU cables.
Thanks in advance.
Announcement:
Shipping will close for Mar 1st - Mar 20th.
I have work that takes me out of town for 3 weeks.
I’m about to place my order, can you please tell me if it’s possible to make the sata cables longer than 10cm please ? I’d like 2 of them but 10cm isn’t enough, need a 15cm with 2 sata power connectors and a second cable with 3 sata connectors total: 2x20cm sata connectors and a 3rd one with 25cm.
Possible ? And if yes how to order please ?
Just to say thanks, received my order yesterday and went into my parts box (I’m gathering odd parts for a near future build).
I’d be grateful if someone can provide a pic of the extra platinum wire that needs to be plugged in to the GPU and how is supposed to be done.
Thanks again @Thehack
@Thehack I currently have the M2427 for my SF600 -- but just recently upgraded to an SF750. Is there a different in the two models? Can I use my M2427 for either? Or if I need to upgrade, can I trade up (send you my module)
Hello,
The only difference matters if you are switching from GOLD->PLAT, as that requires additional sense wire pinout.
Otherwise, they are the same.![]()
Dumb q, but is there any way to estimate an eta on the m2426 getting back in stock?
@Thehack can you ELI5 why 6 wires are enough? Is m2426 safe to use with a 125W CPU, GPU, and a bunch of fans and RGB devices?
Also curious for an answer to this. I have my OC 9900K that pulls 150W alone, not taking into account the rest of the board and peripherals. Can it handle a load of say 200W if I feed GPU from the PSU and not the m2426?
EDIT: Okay, so I’ve done some research regarding my own question. The 24pin doesn’t power the CPU. It’s essentially motherboard power. The 8 Pin powers the CPU. So if you are concerned about power draw for a high Watt CPU then get the version that feeds the 8 pin direct from you PSU and you won’t have any issues in regard to the power restrictions!
