had some time today to cut the first parts, guess I can test the prototype next week...
Interested to see what you think of that Flex PSU. From what I understand, apparently the design of that PSU is "inspired by Enhance 7660B" but not made by Enhance themselves. Another problem is that they also advertise it as "7660B" and "7760B" which i am skeptical of and also doesn't help because Enhance doesn't even have that model number.
An opening up of the 7760B, showing the internal:-
Stress test of the 7760B:-
smallformfactor.net
Do you have an expected launch for this? I'd be very curious to see if a 120mm AIO with a slim fan could be put under a deshrouded itx card. That would be truly amazing.
I'd also happily volunteer to do some test builds as well![]()
Nice, in any event, it's a super cool concept. Please do let me know if you need beta testers.I've send two beta unit cases out for powder coating today. Should get them back end of next week.
I don't think a normal AIO with dual slot ITX card would fit. maybe could do a small custom loop with an slim XSPC rad and 15mm fan. But I'll have to check.
TX120 Ultrathin Radiator — XSPC - Performance PC Water Cooling
SKU: 5060596650008 The XSPC TX is the worlds thinnest PC radiator. At just over 20mm thick, it's 20% thinner than a standard 120mm fan and over 40% thinner than our EX series radiators. Despite its size, the TX series offers both excellent performance and low flow restriction. This comes from thewww.xs-pc.com
So this is the idea of a similar case I had - move the ITX card so that it sits flat against the same panel as the mobo. In the now empty space where you would have had the ITX card and 70mm CPU cooler below it you fit a vertical 240mm rad. With a TX240 and slim fans and a low profile cpu block it could fit in close to the same width as the flex psu.I don't think a normal AIO with dual slot ITX card would fit. maybe could do a small custom loop with an slim XSPC rad and 15mm fan. But I'll have to check.
Nice! Thanks for checking. I have an IS60 EVO that I could use, but wanted to give the a deshrouded PNY 1660s (1ish slots) a shot over it. From eyeball math, removing the single fan cooler gives about 20-22mm of clearance, which with the 33ish mm should be juuuuuuuust enough space for a 27mm rad and potentially a 25mm fan. Im sold on trying out the concept any in either event, so I'm definitely a buyer on the case. Thanks for posting the pics
Exactly! And yes those are the exact parts I haveyou mean like this? could work if I increase the volume to 7L. you would have to use an ALPHACOOL LT, 15mm fans and XSPC 20mm rad.
Awesome. Looking forward to itI'm happy to send you one of the first cases to try your ideas for a discount price. Probably needs some modding but I'm curious what you will build with it.![]()
the family is growing...
please identify the case to the left, of your soda can. your thinnest case.
smallformfactor.net
