I'm affraid you're right but AMD should be coming up with a 16gb card and I'm hoping that will be a little more reasonable.Box of tissues ready to weep at the cost
You dont need to add tape to the logo, you can take off the outer silver bezel as it just snaps into place, and then that exposes two screws for the acrylic. Unscrew those and flip the acrylic and screw it back in. It's how I flipped my corsair logo.Here you go
Here you go
Right now The 92mm is held by double sided tape as this is just a test fit (hence the missing screws). Will think of something more permanent when the build is finalized.
For the specs same thing this is just a test fit with my current build (R5 3600 + 1080Ti) but the plan is to upgrade to R9 4900 and RTX 3090/6900XT whenever possible.
Also, I'll prob add a vinyl cover on the flipped corsair logo it's triggering me lol
You can, but it was a tight fit and the tolerances on the radiator could mean that it might not happen flawlessly with every H100iIt looks like you can push right angled end radiator from H100i RGB XT also all the way to the front or I am missing something? Anyway as soon my parts arrive I'm going to try similar 3 fans setup with Cooler Master ML240L v2 AiO
I would like to know this was well. My EVGA 650 GM fan has a really loud bearing or the turbulence caused by the fan "grill" makes it super loud, it's the loudest fan in my system and spins up when im doing basically nothing. Really annoying tbhQuestion for those with the corsair sf series. How often does the fan spin up and how loud does it get?
I have the evga 550 gm which is plenty for my system in terms of wattage but the fan tends to spin up quite frequently and it's quite loud.
@fabio I think I have come up with a configuration you haven’t tried.
Requires a bit of surgery though.....
And a bit of knuckle scraping.
Nice build!
You know the RGB cover pops off so you can spin it 180º to have it the right way up?![]()
since you already have an sfx psu, i wouldn't bother spending the extra money on the corsair sf series. just buy an nf-a9x14 and swap it in. it works wonders for sound.Question for those with the corsair sf series. How often does the fan spin up and how loud does it get?
So I saw brief mention of it earlier but don't think anyone posted a build with it. Would the EK-XTOP DDC 3.2 be a good pump/top combo for this case? Assuming a reference card for GPU length
@worldtour sexy looking GIF there! How did you secure the 120 fan over the motherboard?
Edit: plz don't roast me for the cables too much. I promise I will clean them up.
Question for anyone who can answer! I ordered a T1 Sidearm a couple of days ago, but just noticed that there are versions of the front panel that have slots along the left hand side. Is this a USB C 3.1 slot? Or something else? Would I have to buy this panel separately or does it come with my order? If I do need to buy, where can I? Sorry if this is a stupid question, but the images don't make much sense to me and there was no mention on the specs page when I ordered...
Hi guys,
Received my case without any issue
Surprisingly, you can fit 3 fans with a H100x (27mm thick) with 0 bulging. The rad doesn't have the squared ends the H100i has meaning it goes all the way to the front. That gives you the room to fit 1 a12x25 below and 2 a12x15 above.
You can also fit a 92mm a9x14 around the m.2/VRM area even in 3 slots mod, you have basically the perfect clearance before the fittings get in the way (This was known to work with custom loops because of the thin block but I don't know if people knew it worked with some AIOs.)
Might make the H100x a great aio choice.
If it interests anyone I can take some photos.
Hey. Tried searching this thread before.
Did anyone try putting/stacking 2 2.5" SATA drives? is there anyway to shove a second 2.5" at all.
According to @Navic's build, only one seems like it.
You can stack them using double sided tape, but I think you might need to get some custom, lower profile cables. Might not, but there are some other ways.Hey. Tried searching this thread before.
