Here you go
Here you go
Right now The 92mm is held by double sided tape as this is just a test fit (hence the missing screws). Will think of something more permanent when the build is finalized.
For the specs same thing this is just a test fit with my current build (R5 3600 + 1080Ti) but the plan is to upgrade to R9 4900 and RTX 3090/6900XT whenever possible.
Also, I'll prob add a vinyl cover on the flipped corsair logo it's triggering me lol
Another T1 Brit. Welcome to the club.Mines cleared UK customs this afternoon, it's getting close! Wasn't even meant to ship until 24th-28th so it's all going pretty smoothly and ahead of schedule thus far
Hey. Tried searching this thread before.
Did anyone try putting/stacking 2 2.5" SATA drives? is there anyway to shove a second 2.5" at all.
According to @Navic's build, only one seems like it.
I was able to fit two between the front panel and and the psu. You'll just need custom sata power cable from pslate or angled sata power cables. No need for double sided tape because it'll be pretty snug in there.
Just make sure if you do get the cable from him the little bit of cable that connects the sata connectors should be shortened by a little because mine does go into the second ssd at angle and makes contact with the psu and can potentially loosen when messing around in the case.Oh! This is the ideal situation. Thanks for sharing this picture.![]()
How are your VRM thermals with all those cables blocking airflow?Trying to update my cable management, last time show like this
And turn out like this
I need to check @thelaughingman post, I'm trying to put 3 fan and failed.. WIll try another time.
will try to figure out too.. thanks for the questionHow are your VRM thermals with all those cables blocking airflow?
flipped PSU is too tall, there's not enough clearance to bend the tubes. You need to leave the PSU in default orientation and bend the stock cables / use slim custom cables.I need to check @thelaughingman post, I'm trying to put 3 fan and failed.. WIll try another time.
