Stalled DICE CASES - FLOW : expandable SFF case for watercooling enthusiast (built in distroplate)
ChorizoNinja
82
101
Well well...
Look what I found digging in the ekwb webserver tree...
Those blocks are for the 8 pin cards reference design cards, that are not the nvidia founders edition. The gigabyte 3090 gaming and eagle have a semi custom PCB with one phase more and probably are not going to be compatible with this block. 15 vs 14 phases for the core, memory is unchanged.
Reactions: diceboii13 and D10S
diceboii13
620
1,644
dicecases.com
When is the next batch? Will it come with PCIE 4 cables? Same price or extra charge?
I hope in this Autumn, but it depends on our vendors as well. Last time I asked about gen4 they said it's under testing, so I have to ask again ?
Cool, so I assume we will be able to order that separately later?
Yes directly from the vendor, so easier.
Reactions: an_Age
dotnetapp
24
Well well...
not compatible with founders edition
AllXFrag
96
135
We are a secret lovers nothing else.. ? ? ?
It sounds like a bit "boomery" but im not into that discord thing.. I never used it, so if someone want to make it I will join no problem ?
Now to adress the elephant in the room... Did they ship the cases? Have they arrived? ?
Reactions: Whippler
TheBigG
46
@diceboii13 will the case arrive within the next week in germany? If not I have a problem because I will be 3 weeks on a holiday trip and i bet the postal service will return the case to you, or if you take now three weeks more I'm fine ?
