Dude this question was answered literally on this page, scroll up.How long should our custom cables be? Should we base the lengths off a NCase or a similar sized case?
About as the same as the ghost or the dan, or the slinger ones. This is the same layout, maybe the GPU cables can be a bit longer like 1-2cm. Other peripheral cables are depends on your expands and drive places.How long should our custom cables be? Should we base the lengths off a NCase or a similar sized case?
You kinda need a place for the motherboard IO Shield and the GPU IO bracket...Crazy idea - back panel is distro plate too, without any pump mount.
Yes, but signifficantlly more expensive aswellI know. But if possible in future make it acrylic with some water inside, it will be look more outstanding.
Currently not, but I should give it a try. In here middle Europe its not that famous.Do you have a Twitter?? Probably the easiest for me to get notifications on Twitter for any announcement you make
Prices are finalized I think:
- Flow with distro: 225 € (~250usd) included the riser cable, power cord, distroplate, some screws if you lose it
- Flow with vented front: 165 € (~180usd) included the riser cable, power cord, screws
- Distro replacement front panel: 59 € (~65usd) if you want to change your expand and still keep the covered look
- Front/Back panels with all expands, 3slot backplate, sidepanels seperate: 19 € (~21usd)/piece
- TG sidepanels seperate: 29 € (~31usd)/piece, but if you order the case with TG sidepanels the price will be just 10€ more, so you got 2 TG panels for 235€.
Tonight I gonna make a poll about some colors variations, because I cant chose. If I miss anything just leave a comment! In this week I got the colored pieces, and I prepare for the preorder. We are close!
