I mean build like this:
- rad - ______ A
- fan - ______ |
-case- ____ air
- rad - ______ |
- fan - ______ |
- rad - ______ A
- fan - ______ |
-case- ____ air
- rad - ______ |
- fan - ______ |
whatI mean build like this:
- rad - ______ A
- fan - ______ |
-case- ____ air
- rad - ______ |
- fan - ______ |
You can do, but it doesnt make any signifficant difference. The cooling performance almost the same in both in theory.Air goes from bottom grill through case and push out by top rad fans.
On all renders air goes from rads, not to rads.
I remember someone on this site once explaining that if you have air comming from one rad moving into another, the heat dissipation if the second rad is significantly worse because it’s starting from a higher temp. If you have 2 rads both should either get there own air supply. I am not sure if this theory holds up on tests, but it makes sense.
Its true, ventilated sidepanels will be an option too. How about ventilated acrylic?I know that held true for me. I previously had a mid tower case with top mounted 240mm and rear mounted 120mm radiators both set as exhaust with front intake, I thought I could get better cooling by replacing the rear radiator with a front mounted 240mm radiator. My temps went up a few degrees with this setup.
What I would actually like to see with this case is ventilated side panels and that way you could run top and bottom radiators in exhaust, although I know a lot of people will want the glass side panels to show off their builds.
What mod covers do you mean?Is possible made d5/ddc mount hole with thread/screw holes for mod covers?
Sure!Any chance of vented steal/aluminium side panels instead of acryl ones? I don't have to see my hardware and prefer better ventilation above the view on my hardware.
*2032I actually would prefer to have something simple to buy before all that custom stuff get done. Dual slot for the GPU, 2*280 rads and a distroplate with pump and a flow indicator. That's all I need. With all this change requests, I fear that it goes the same route like the Dan c4 and there will be nothing beside one prototype till 2022.
I listed all the features, what you guys asked, and I try everything. Right now I just finished modelling the inner parts from 0.9mm steel. I make the radiator mounts more "ventilated" for 280 rads. The next thing is try the 3 slot gpu. I will post some pictures soon.I actually would prefer to have something simple to buy before all that custom stuff get done. Dual slot for the GPU, 2*280 rads and a distroplate with pump and a flow indicator. That's all I need. With all this change requests, I fear that it goes the same route like the Dan c4 and there will be nothing beside one prototype till 2022.
