DAN C4-SFX & C4-MATX
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
3,042
4,518
guilleacoustic.wordpress.com
Technically, the maximum safest power for an 8 pins cable is 288W (8+8 is also 288W, but combined).
prayogahs
237
344
Corsair thinks you only need 2 since their replacement cable for the RTX 4090 only has 2x8 pin PCIe.
Its not PCIe though. It is a Type 4 pinout that is used for both CPU/EPS12V and PCIe and it can deliver up to 300W each. Hence the 2x8pin Type 4 is already enough for 12VHPWR to deliver 600W. I dont know why people always forget that the exact same port is used for EPS12V which can deliver 300W. A single daisy chained PCIe cable that comes included in Corsair SF750 already delivers 300W anyway.
Dampfbox
183
252
It has 4x8pin PCIe in two daisy-chained cables. It will work.
I'd rather spread the load between as many PSU-side connectors as possible and the SF750 only offers 4 Type 4 connectors (one of which is being used for EPS12V)
Revenant
Revenant Tech
1,741
2,858
THIS!
I get questions all the time about random GPU crashing only to find out someone hooked up their high power GPU to a single cable but with dual connectors. 288W from a single connector on the PSU.
couchpotato
31
24
THIS!
If a single 12-pin connector can handle 600w, then a single 6/8-pin connector should be fine for 288w. More likely the cable is too thin to handle the current to avoid excessive voltage drop, thus GPU instability.
remotebert
21
37
dondan
DAN Cases
1,966
8,288
Slim Profile? 🤔 Yes in comparison to the included Y-Adapter it is "slim".
The new Corsair SFX 12VHOWR accessoires cables is only 15mm in height with cables bended. This adapter will not fit on a RTX 4090 FE inside the C4-SFX.
C4Me
@dondan
Is that Corsair cable accessorie only compatible with Corsair PSUs? Will this be a problem with other AIB cards with the C4?
I have a Silverstone SXL-1000w and hope that's not the case.
ScottSimply
136
235
@dondan
Yes Corsair's cable is only compatible with Corsair PSUs.
Silverstone has their own 12VHPWR cable but I don't think it's available separately.
Custom cable makers should be able to make some for your PSU though.
Reactions: DrHudacris
