DAN C4-SFX
steelfractal
Aug 15, 2019
470
596
dondan
DAN Cases
1,981
8,392
If you deshroud the GIGABYTE GeForce RTX 4080/4090 Windforce 24G und remove the backplate it will fit in the C4-SFX 14.7L.
With deshroud the height will be reduced from 331x150x70mm to 331x137x70mm.
Here are the cards that will fit in the 14.7L
INNO3D GeForce RTX 4090 X3
Palit GeForce RTX 4090 GameRock
Gainward GeForce RTX 4090 Phantom
INNO3D GeForce RTX 4090 iCHILL X3
NVIDIA GeForce RTX 4090 Founders Edition
MSI GeForce RTX 4090 Gaming Trio 24G (Ultra close but mayber fit)
KFA2 GeForce RTX 4090 SG
Should fit with deshroud:
GIGABYTE GeForce RTX 4090 Windforce 24G (aslo remove backplate)
MSI GeForce RTX 4090 Suprim X 24G
junglist724
As someone in the US I don't think any of those AIB cards that fit without deshrouding are actually sold here. So I'd prefer to get the 13.37L version and just try to get a 4090FE or go AMD.
DrHudacris
918
1,720
I went to Best Buy’s website and it is still in stock. Corsair did not have them listed direct but I found it through the retailers link. You have to copy the model # and search Best Buy for it though..
Did I miss it? It's no longer showing up on the best buy website
Diesel
Sry I cant resist XD
It is rdy for production but NVIDIA changed the game. It was not an easy decision to delay it but I need to wait for AMD RDNA3 to release the 13.37 or 14.7L version.
I already put hundrets of hours and thousands of dollars in this project , I am very happy with the quality and performance of the product so this will definitely hit the market!
I never said wait for this case if you need a case right now get something else.
Firstly, that's brilliant, bravo 👏
Secondly, I do understand, I really do. BUT, you did the same thing over a year ago when the 3 slot GPUs started becoming more common. You can wait, but there will always be something around the corner. You've effectively come up with 2-3 products so far which you've binned. You could have released them and moved on to the next iteration.
Reactions: dondan and Dampfbox
