DAN A4-SFX v4.1
NavCrow
I've recently installed the Alphacool Eisbaer LT92 in my Dan A4 V1. Obviously, as the V1 does not have the holes at the bottom for airflow, i've had to drill them myself.
There's been a thread on the fitting of the radiator, and it was said that it (probably) won't fit. Thought i'd buy one, and it fits without any issues! (Altough i did have to swap out one of the fittings to a 90 degree fitting,i've used the the EK-AF Classic Angled 90°).
I did have to cross the tubes as they were too long, so the angled fitting on the motherboard side points to the gpu side. Could also just have cut the tubes ofcourse.
(More pictures Here)
In the above picture, i've fitted a NF A9x14 as that was the fan that used to be on my Dark Ridge, but it has recently been swapped to the NF-A9.
Performance and noise is great, keeping my 9900k cool. I will get some prober numbers later.
Full specs/info:
Cooler: Alphacool Eisbaer LT92 with the NF A9x14.
Fittings: 1 stock straight fitting, one has been swapped for the EK-AF Classic Angled 90°.
CPU: 9900k
Motherboard: Asus ROG Z390 Gaming-I
RAM: Gskill Trident-Z RGB 3600mhz
GPU: Gigabyte RX 5700 XT GAMING OC
Case: Dan A4 V1
Casefan: NF A9x14 under motherboard
PSU: Corsair SF450 with NF A9x14
Storage: 2TB NVME, 1TB NVME and 1 Sata SSD
Got any longer term updates on how this turned out, thinking of trying this bad boy out?
prideauxdc
Has anyone ever had an issue with their GPU not fully sitting in the PCIE riser?
Just got a new 4.1 and MSI 4070 Ventus, and you can kind of see it in the image below that the left side of the GPU is higher than the right when attempting to seat the GPU fully in the riser - there's no way to get that left side to go in completely.
It looks like what's happening is the support bracket on the GPU is preventing it from fully inserting...not sure if the problem is the location of the GPU bracket (too low), PCIE cutouts in the case (too high), or the installation of the riser (too low).
Not sure what to do, other than maybe trying to drill some additional holes in the riser so that I can lift it up a few mm. Or maybe having it slightly angled is ok and won't cause any stability issues...
I had this issue yesterday while building my second Dan A4 for the wife. It’s not quite level is it? Seems to make a close enough connection for me though.
On an interesting side note; the build for my other half I wanted to make as quiet as possible and she only does light gaming. I looked at the KalmX 3050 but the specs are not worth it, even though it’s good for what it is, and the fin stacks are in the wrong orientation.
I settled on the Strix 4060 which is a three slot 310mm card (yes I know). I removed the shroud and screwed the back plate on with some nylon M2 bolt/nuts with washers (shroud holds back plate on). To my utter delight it slid right in and fits perfectly, with maybe a mm or two to spare. I like to call it the Kalmx 4060 😝
Stress tested and no worries, with the bottom fans pushing air up at minimum RPM it barely reached 70.
Reactions: Dawelio
Theelichtje
Still using it, and still going strong! Since the picture, i've removed the PSU mounting so i had a bit more space, and squeezed the noctua 25mm in there, in place of the 14mm, gave a nice little boost in cooling and noise.
I've actually rebuild the PC yesterday, i'll post some pictures soon, i'm now using an HDPlex 500w DC-ATX underneath the gpu after my SF450 died, should be quite interesting.
This means i have now put the Alphacool 92mm rad on it's side so it has better acccess to fresh air. Wasn't able to get any benchmarks yet (also not sure anymore at what temps it ran before, but i know i wasn't able to sustain a 5ghz OC before, so interested to see how close i can get now.
Long story short, the cooler is doing great, still low noise, pump is barely audible, and cooling great! What CPU are you thinking about using it with?
prideauxdc
I've actually rebuild the PC yesterday, i'll post some pictures soon, i'm now using an HDPlex 500w underneath the gpu after my SF450 died, should be quite interesting.
Interested to see how you’re fitting the HDPLEX 500
Ngeloms
Okay guys, so....
For whatever reason I decided to put my finger on my RAM sticks during heavy gaming and noticed they were hot as hell. Is it normal? I use my PC without side panels.
Reactions: prideauxdc
CubicFrog
Full specs/info:
CPU: 9900k
Case: Dan A4 V1
Hi, I know this is an old thread but I’m hoping you get this as I want to install the exact same setup as well. You mentioned you swap the x14 for the 25mm A9? Do you have pictures for that because I can’t see how I can fit a 25mm fan in there with the wires coming out of the psu. 🙏🏻
2,703
2,832
Here are a couple of examples of cable management in the A4-SFX, one and two. just google Dan A4-SFX cable management for more. Also get yourself a fan grill and then you don't have to worry so much about the cable management.
CubicFrog
Full specs/info:
CPU: 9900k
Case: Dan A4 V1
Hi,
I know this is an old thread but I’m hoping you would reply as I’m planning to do exactly the same thing. You mentioned that you swap the x14 for the A9 which is 25mm thick. Do you have any pictures ? I’m looking at my build and I don’t see how I could fit anything other than a 14mm thick fan because of the wires sticking out of the bottom of the psu. Thanks in advance. 🙏🏻
CubicFrog
Hey thanks, I do have a fan grill but I have the asetek 92mm rad plus the A9 NFx14..and it fits but I can’t see how to fit a 25mm thick fan above the rad. That’s why I’m asking him for pictures of his build.
nightshift
297
200
With the Asetek rad, you need the LoserCard mod that elevates the psu a bit. However, it's still very hard to accomplish cable-; and tube management without a custom shorter 24pin - yet the case will still feel stuffed. To be honest, I'm not entirely convinced if it's worth to use the Asetek aio over some nice air cooling options like the L9a + duct or an Alpenfoln Panorama 2 which offers similar cooling but longer consistency and a roomier build with more airflow.
axtran
77
71
I'm still an A4 addict, so here I am looking to optimize some more... just picked up a 5700X3D and was wondering if it's technically less heat than the 5600X3D that's currently in the system. This seems so niche that I guess there's only one way to find out...
CubicFrog
Thanks for the reply, I do have custom cables for my entire Dan build so wouldn’t be a problem. Can I still get the loser mod from someone? Or a 3d print ?
axtran
77
71
Good news!
Just decided to light some money on fire and update the travel PC since I use it so often... ended up going with a 5700X3D paired to a 4060Ti 16GB. The combo is pretty low power consumption so I was able to reuse my power supply again (SF450 has been in service since 2017) and the CPU cooler can finally keep up without going to full wind tunnel!
Here's how it looks for those interested:
Top CPU temps when playing my typical game rotation was 79.6C, and that's at PBO All Core Curve Optimizer @ -30. I could never get that to actually stick with the 5600X3D!
nightshift
297
200
Good news!
Very nice:) But where did you hide the 24pin?
ZTylerDurden
65
46
Quick question. I've had bad luck with riser cables. Had to replace it 3-4 times over the years cause of PC instability.
Anyone else had this issue at least once or twice? I've owned Lian-li and third party.
