My A4 V2 should arrive next week and I was curious about something.
The maximum supported cooler height is 48mm, which is the exact height of an L9i with a 25mm fan on it.
I ordered a couple of 92mm redux fans and wanted to know if there was a particular reason more people didn't use the redux here if it does technically fit?
Obviously with the Window panel it would fit fine, but those aren't available currently...
Hey Thanks for your answer. After some research I found that if the motherboard supports, you can have a M2 SSD on it, which takes me to 3 storage space. (2 2.5" and 1 M.2)
However, if the M2 slot is trapped behind the motherboard, how does the temperature goes because it is sit tightly between GPU and motherboard?
Awesome! One final question if anyone would not mind answer it.The temps should be fine, but if you still have fear, you can buy a MB with the m.2 at the front. It should be said that
if you have a m.2 with a heath sink and and an watercooler for the CPU, the m.2 can run little hot cuz of none direct airflow. If you have a air-cooler you can use the heatsink of the m.2 because then it has pretty good airflow.
Thanks heaps for the detailed reply, I have a couple of the redux fans anyway so I will test out but I'm sure you're correct in turbulence from the proximity to the side panel. Some preliminary tests I ran were really good though, the redux is completely inaudible and I feel like with the windowed panel granting some extra space, while it may reduce airflow slightly, the extra space to the panel will reduce turbulence.1. The Redux is an older design and is actually worse.
2. The fan needs to be at least 5mm away from the side panel to avoid turbulence. It is a very often reported concern.
3. The L9i is pretty much at maximum dissipation so a better fan does little to improve to the overall performance.
Here is the most expansive GPU in the world (Quadro GV100) inside the A4-SFX. Thanks to PNY for the pictures
Super jeally!! How’s the noise levels with that NJ450 in there?
I believe the standoffs come installed but if there is no gap between the motherboard and tray DO NOT turn on the system, remove the motherboard and attach the standoffs to avoid shorting your board.Hey guys
Quick question: I followed the guide that came with my Dan case and my build went together smoothly. However, once I was done I found that there were 4 standoff screws in the screw bag that I did not use.
Were these screws supposed to go under the motherboard? The manual did not tell me to install stand offs, so I screwed the motherboard down directly onto the case.
They will be, only AIB cards will potentially be more, but all reference card designs are 2 slot by design as this is the industry standard.I hope this new series of Nvidia card will be two slot card. They will be the first ever card for my dan case.
Dan Cases A4-SFX V3
Silverstone SST-NJ450-SXL Fanless
Asrock Fatal1ty Z270 Gaming-ITX/ac
Intel Core i7-7700T 35W, ~200 Gflops measured
Noctua NH-L9i
Corsair LPX 2x16GB=32GB DDR4
Samsung 960 PRO 2TB
NVIDIA GTX 1080 Founders Edition
CableMod 24-pin ATX 250mm
CableMod 8-pin EPS 250mm
CableMod 8-pin PCI-E 250mm
You need to use standoffs with all motherboard installs. Not just in the A4Hey guys
