I'm looking for a "CPU holder" This means a construction that you attach to the underside of the desk to put a PcTower pure. (I did not know myself). Then he must no longer stand on the floor or table.
This here would be a very inexpensive
Width from 8 to 77cm
Height from 5 to 80 cm
Depth fixed 28 cm
Do you think this is good for the Dan ? Of course the bands will block the airflow a little but for that the tower is also further away from me and I higher the more RPM not .What do you think ? Have before me an electrically adjustable table to buy and the Dan should be made below rangemacht. Would be so far less dust in the case find. Good bad ideas or do you know alternatives? Thanks
Translated with www.DeepL.com/Translator (free version)
Depth fixed 28 cm
