Stalled Custom_MOD MINI
Khord
I am preparing two new versions of the case. One will be longer by 10mm with the fastening of the SSD from the front (also it will be much more convenient to install long video cards up to 180mm) The second version is 40mm longer (for Zotac 1080 mini)
If I want to order in batch 6, will it be possible to get the 10mm longer version?
W1NN1NG
616
532
@Curiosity
Tom's hardware measured the evga sc 1060 at these dimensions 18.4 x 10.5 x 3.5cm with shroud. So evga definitely needs to fix their measurements for sure. I'd pick up the MSI aero 1060 as it is exactly 175mm from the Pci bracket and try that out. Unless you want to wait till I get my case lol
Reactions: Acalanata
K888D
Lazer3D
Feb 23, 2016
1,483
2,970
www.lazer3d.com
@Curiosity
I've been saying this since the 900 series ITX cards as they use the same shroud yet are also listed as 173mm I think.
QuantumBraced
507
358
If you recently ordered the card from EVGA or Amazon, I would return it and demand a full refund including shipping because of incorrectly reported dimensions.
Reactions: W1NN1NG
Curiosity
Apr 30, 2016
741
866
@Curiosity
Unfortunately I can't afford to do that right now, so my current plan is to mod the snot out of the GPU and maybe a mod or two on the case.
I bought the card for my move to the S4 mini back in February, when this case was still being called 'korkin'. So at the time the incorrect measurement didn't matter. I will be emailing EVGA to point out the issue to them though.
wabbitro
25
has the dimensions changed since batch #1? my evga 1060 sc fits
W1NN1NG
616
532
See that's odd to me. It must have changed or something. Can you post pictures of yours @wabbitro
Curiosity
Apr 30, 2016
741
866
Visually comparing @TheHig 'a batch one and my batch two, the front panel is permanently attached in batch one, probably eliminating the rivet, and on my batch two there is a lip on the back wall of the case (over the mb I/o and pcie slots).
I think those are my two biggest stoppers.
I feel the need to point out: I love this case, even with the issues I'm having.
Acalanata
38
25
Me too but I need to put a videocard in this tiny case to play, so I'm really worried if the GTX 1060 and 1070 (175mm) really are compatible with this revision case.
W1NN1NG
616
532
I'd say you have nothing to worry about if you either a buy the version that's going to be 10mm longer OR choose a different 1060 or 1070. Based on my measurements the msi aero 1060 will fit.
@Curiosity s fits with the shroud off basically albeit a pain to get in the chassis. To free up space against rivet he also spoke on behalf of you've got 2 options. Drill the rivet out and epoxy those 2 pieces instead OR clamp and line up the holes together and tap rhem and then screw them together instead. Which is probably what I'll be doing to all of them anyways.
W1NN1NG
616
532
See this blows my mind how it even fit to begin with. I'm trying to figure out how I'm even going to seat mine in the chassis. Seems like it's going to be a real challenge. Since mines right at the limit
wabbitro
25
maybe V1 was longer. i roughly measured it at 184-185mm from front to back. and i have around 10mm space from the front of the gpu to the front of the case. enough to stick my wires in there.
Curiosity
Apr 30, 2016
741
866
I thought I had posted this here but I hadn't, here's the fit at the front of the case without the shroud in mine.
Since the shroud is too long.
