Am I blind or is there no PCIe 8-pin connector on your G-Unique? Is the red connector CPU or GPU? And in either case, where's the other one?
Lol they're both there CPU is in top left of picture next to the sata and the PCi is the red oneAm I blind or is there no PCIe 8-pin connector on your G-Unique? Is the red connector CPU or GPU? And in either case, where's the other one?
I'm really excited I may make a vlog for the build if I can figure out a way to get my phone to sit while doing so. I don't have a secondary PC soOh right, it looked like a SATA connector from that angle. Cool, I can't wait to see pictures of the build!
Right? Lol probably what I'll do. And of course I will do portrait mode because everyone wants to see a video like that right? RoflJust get a cheap smartphone stand. Just don't record in portrait mode haha.
I'm hoping I don't have a similar problem with the aero itx 1060my shroud doesn't extend off the PCB though so I might be alright. Weird yours doesn't fit.So my EVGA 1060SC doesn't fit..
Getting the PCB in alone is hard enough, with the pcie bracket it's impossible. Shroud won't fit, and the rivet holding the Mobo to the front plate bends a fin on the heatsink.
Looks like I need a different GPU.
Edit: I measure my PCB at 173mm.
How much room is to spare for the pcb length?So my EVGA 1060SC doesn't fit..
There was probably 2_3mm between the PCB and the front end of the case, but like I said, it was damn near impossible to get in as is, I'm not sure something longer would fit, at least in my case.How much room is to spare for the pcb length?
I hope not because mine is apparently 2mm longer than yours. Granted the fin design is different in my situation and I think the aero is slightly slimmer. But I'm not sure. Hopefully it works out with shroud attached. Doesn't make any sense as to why yours doesn't fit though. Maybe your PC extender isn't scooted far enough to the back of the case which is why it may not work with your PC bracket?There was probably 2_3mm between the PCB and the front end of the case, but like I said, it was damn near impossible to get in as is, I'm not sure something longer would fit, at least in my case.
Maybe there design changes between V1 and V2 made the max length shorter? I'm not sure.
Can you post a picture from above and front?There was probably 2_3mm between the PCB and the front end of the case, but like I said, it was damn near impossible to get in as is, I'm not sure something longer would fit, at least in my case.
Worth noting that's with the shroud off, the heatsink on the 1060sc is good with the edge of the PCB.
Yeah the aero has an indention on the heatsink around where the rivet would be so I should be fine in that regard. Plus my shroud doesn't extend off the edge of the PCB at all. I measured it just a few minutes ago and it measures a hair shorter than what MSI claims luckily. So mine should be a perfect fit. I'm hoping. It barely extends past the motherboard so it should be perfect I'm thinking.There was probably 2_3mm between the PCB and the front end of the case, but like I said, it was damn near impossible to get in as is, I'm not sure something longer would fit, at least in my case.
The recommended thickness is 38.5mm. Please measure your video card. There is no thickness on the official website.So my EVGA 1060SC doesn't fit..
I don't have calipers on hand at the moment, but the card is no wider than the PCIE bracket.The recommended thickness is 38.5mm. Please measure your video card. There is no thickness on the official website.
