Pretty sure it's SFX since the last version is SFX, an this one is a bit larger.This is dank AF. is this going to run an SFX psu or a picoPSU?
Thank you! I don't have any 400 units I can sell unfortunately. I'm working on finalizing the design for the 401 and my goal is to have something ready for ordering around April/May. I still don't have production cost estimates as the design is still changing slightly, but as soon as I get those numbers I will be able to make my decision regarding a kickstarter or direct sales. All ordering information will most likely be revealed at the same time I start the new thread that will contain photographs and specifications. The prototypes that I have made and are production quality I will be reaching out to entities in hopes to get some reviews posted (hopefully those will be in the hands of people for review around the same time I start kickstarter/direct sales).I am interested in s401 and any s400 laying around if available. Amazing job btw.
Wow, the ATX (?) version looks incredibly gorgeous and unique, although the top panel looks a little funky since it's just two small ones squeezed together. If it looked a little more like the front panel it'd look great. As for the 401, I don't know how I feel about the front panel design, since the hex pattern doesn't take up the whole pattern. For example, the ATX version looks awesome from the front.
How do you plan to get a pcie extension in the 700? (I don't see a spot for it...
Looking good. : )
Looks great! So now you're working on two form factors ATX and mITX right? sorry if I sounded dumb because I'm little bit confused. Many thanks!Update with some components installed:
Is that because there are no threadripper itx/matx?Yes - the mITX is my primary focus right now though. I'm not sure the ATX will be available because it will be expensive to make. I will however have at least one of the ATX case made for myself so I can finally build my threadripper system.
There is a TR4 mATX board I think (ASROCK?), but the real reason it probably won't be available is that I don't have the money to produce it right now. Maybe after I get the S401 out there and get a few sold I'll be able to research costs and options, but for now I may only have the initial prototype made so I can finally upgrade my i7-3930k system I've been using for years.Is that because there are no threadripper itx/matx?
Congratulations on your daughter! A SFF PC means more room for childrenKids just mean less upgrade money
I know the pain quite well!
Great work thus far, can't wait to see a physical prototype!
