- Feb 22, 2015
- 1,052
- 1,990
Hmmm so about pricing, if you switch to aluminum would pricing be the same or cheaper (as I was shooting for around 150 USD like the Ncase M1).
We're making a case with a design and development process second to none, with the best materials and manufacturing available to anyone in the industry. We're carving the feet out of aluminum billets, it's of that caliber. This is not meant to be a $150 case.
Neither is the NCASE M1, by the way. That enclosure costs $185, is manufactured in Taiwan, and is ~2/3 the size of our enclosure. They also use plastic, off-the-shelf feet, which I mention not to criticize, but to emphasize how fastidious we've been.
Ours comparatively will be US-made, 50% larger, and will (relative to the M1) be very competitively priced IMO (though the two don't really compete directly).
Cerberus will be pricey, but it will be of very high value for the users it is designed for. This is an enclosure that is meant to outlive generations of hardware. This is an enclosure that provides features and compatibility/volume that are not remotely close to being reached by any other option currently on the market. This is an enclosure and passion project by and for enthusiasts.
I wouldn't mind an Al case. A steel inner would be nice though, stability, rigidity and all that. Al I can get oxidised for a lovely oil-on-water shimmer effect, which is really hard with steel![]()
We will not be compromising on stability/rigidity/strength no matter what we end up doing. It's just that, if we use aluminum with the internal chassis, that means we are forced to use a thicker gauge to get that, which will either increase the external dimensions, or decrease the internal tolerances - and either way, we have to do a bit of work to re-factor the design with the thicker material.
Everything else - features, finishes, design, etc - would be unchanged. We'd just be changing the metal used. Benefits would be a much lighter enclosure and the perception (by some) of higher quality; the drawbacks would be the thicker gauge, a potentially higher cost (though we might scrape by - waiting on quotes currently), and a loss of the ability to use magnetic filters without putting magnets on yourself.
