thanksPush-pull as intake
did you put top fan on side bracket or using fan clip?
I'm always interested if you tried exhaust mode..
I mounted the side fan in the bracket, it allows more airflow since with clip part of it get covered by the side panel of the case.thanks
thanks for sharing.I mounted the side fan in the bracket, it allows more airflow since with clip part of it get covered by the side panel of the case.
I tried both, intake and exhaust, but in my case temps are better as intake. I have two fans in top as exhaust, and with the case sitting in vertical the airflow is more optimal that way.
@Uruk by the way, did you notice noise reduction by moving to C14S instead of Corsair AIO?thanks for sharing.
You are right with your personal setup (dual top exhaust fans, vertical stand), C14S seems to work pretty well!
Next step is to wait for new Noctua NF-A14x25 with sterrox blades..(2021 apparently..
yeah there're supposed to be threads on the chassis o_o contact supportHey are these suppose to be threaded?
Big difference while gaming. Now I can set graphics card fans to 50-55% (65-70% before) and keep GPU temperatures under 70ºC.@Uruk by the way, did you notice noise reduction by moving to C14S instead of Corsair AIO?
ah ok...big difference on GPU noise as it has access to fresh air..Big difference while gaming. Now I can set graphics card fans to 50-55% (65-70% before) and keep GPU temperatures under 70ºC.
Not really. Take into account that the system have now two additional fans, so I had to tweak the curves to get the same noise level as before in pure CPU load work.ah ok...big difference on GPU noise as it has access to fresh air..
In case of pure cpu load, did you notice some improvment also?
Understood...Not really. Take into account that the system have now two additional fans, so I had to tweak the curves to get the same noise level as before in pure CPU load work.
BIOS. Dont like Asus softwareUnderstood...
Are you using fan xpert 4?
ahah..BIOS. Dont like Asus software![]()
Yeah it is a 5 inch display attached to the back of the psu. There is an additional display on the motherboard for cpu temp and a display on the gpu block for water temp. Custom made glass panel.@DocH is that a display above the PSU? o_o
(also dat space efficiency)
