Necere
NCASE
3,300
I totally agree with the Cerberus X over the base. You could easily argue "What is 1.5 3.7 more Liters for so much more flexibility?", then of course people would argue that shaving every inch is the whole point of the SFF philosophy, but I would argue that being able to fit all the flexibility of the X into 19.5(ish) 22.4 liters
FTFY (because someone has to)
Reactions: Arie and Phuncz
fabio
1,885
4,325
Sorry guys, I have a small but not easy question: do you know how many degrees could add my 2 Titan V to my water loop?
It will affect so much my CPU temp?
Now the 7980XE Overlcocked at 4.3 on 16 core and 4.5 on 2 core, in idle is at 25 degrees average, with ambient temperature of 22.
Under Prime goes untl 85 degrees at 3.8 ghz on all cores. For other test doesn't go above 75 degrees.
My two Titan are 40/45 in idle with the fan at 30%. I would like to have them a bit lower, but especially keep them under 83 for a longer period under load, at least with higher frequencies! Before to put them under water i'll try to give them more fresh air.
Thanks a lot!
loader963
666
571
You could just put the top card under water and leave the second underneath it on air. I think it would easily be fine with your setup, but I don’t know about 2 of them OC’ed with the two rads.
fabio
1,885
4,325
I don't need to overclock them. My concerns are about the increasing temps on the CPU, if any.
CantingSoup
190
100
Just received my waterblock. The motherboard should hopefully come tomorrow, followed by the ram over the weekend.
Edit: The block is huge and weighs 1kg.
galletabah
136
88
I think I have some problems with in the frontal panel in my two cerberus cases:
brianjjy
would a sfx650watt gold be enough for gtx 1080ti black and 8700k oced to 5ghz with 1.26volt and a 240mm aio, 3 drives? I also have 2 noctua 15mm fans as well
FoskcoRS5
Designated LMG
Jan 31, 2017
363
623
Should be fine. GTX 1080ti under full load wattage runs about 300 watts and the 8700k at 5GHz runs just over 200 watts.
Edit: I sourced this information through a series of googles that pointed to some reddit benchmarks.
Reactions: TheHig
CantingSoup
190
100
Anyone know if they make custom cables for the Thermaltake power supplies? I've tried looking for some for my TP Grand RGB 1200W, but I haven't seen any.
kageiit
40
24
If you are concerned with silverstone, Evga and seasonic have good sfx/sfx-l psu with 650w power. I got the seasonic for my new Cerberus build personally.
