I just need the Windowed panel to go live now. I have windowed things that need to be visible
Very very very intriguing.You're going to love what I'm making![]()
I'm getting pimped-out chrome wheel spinner vibes now, LOLYou're going to love what I'm making![]()
Hmmm.....
I am thinking a primed interior, have the case outside in the weather for a month.
Nicely rusted up on the exterior, with copper tubing on the interior.
Working on adding both sides solid as an option for a small extra charge.
Shipments mostly left today, there's about 20 that are going tomorrow but they're all West Coast and will be to people Friday or Saturday depending on mail. Let me know if you did or did not receive tracking, have a feeling something is wrong with tracking confirmation emails.
Any order should get out in 48 hours.
Any updates on the tracking emails, I don't know if I made it into the first batch of cases but now you have my hopes up that I might get a surprise present from myself this weekend
Order #: 1386094700
Will you guys be making the window side panel?, as like the one you had on display before?
So I'm pretty sold on this case. I love the customizability, the modularity, actually being able to buy one and receive it within a decent time frame, it's great. Just had a few questions.
First is the uncoated version going to be cheaper? I was thinking about getting it powder coated locally.
Second, how snug are the USB ports? I wanted to switch one for a HDMI output, but HDMI ports are 1/8" wider. I could always just file it, but if I didn't have to that'd be great, or could you guys do something like that? Just widening the USB port.
Third, is the window you mentioned that might be available going to be glass or acrylic? I worked construction for a long time so I know the strength of tempered glass, but for a machine being used in a portable application, I'd still worry about it breaking and cleaning up tempered glass out of a case would be a nightmare.
Yes, plus a full side window.
It will be Clear Lexan Polycarbonate, tempered glass is a no go.
https://ca.pcpartpicker.com/list/7PqsyfYo I just found the Cerberus case and it looks aesthetically perfect. I'm about to buy myself a new computer for Christmas and would love some feedback from you kind folks before I buy & build this thing!
Please let me know if I should buy a specific case fan or CPU cooler!
Also is the Cerberus available for shipping to Canada? Like can I buy this thing RIGHT NOW and get it NEXT WEEK?
I'm glad you have plans for a full side window. Is there any reason not to have it tempered glass? If it's poly like you said I may try and do a custom tempered glass mod. What is the thickness of the poly panel?
Hey guys two questions.
What size standoffs should I be getting if I intend to put a micro ATX board in the X?
Also, any update on tracking emails? I still gotta order a few things.
Thanks
https://ca.pcpartpicker.com/user/00jknight/saved/ks76XL
I believe the 1080 is more of a difference than that in Canada. The 1070s I looked at in there were like 600. So. The only reason I say Intel is because from benches I've seen the 8400 out performs even in games the ipc just isn't there on ryzen. And the 220 difference wasn't just considering the cPU. The 580 is a perfectly capable card I gave him an nvme and a better storage drive@W1NN1NG
The +$220 difference is hard to justify when you consider that GTX1080 is just $220 more than the RX580.
I think that if anyone is going to spend the extra $220 for better performance in games, they would be better off keeping the R5-1600 and adding a GTX1080 to the cart instead.
To add: If the current trend continues, Intel will likely discard that socket next year. Until Intel comes out to say otherwise (like their rapid response to the core war), you can almost expect Intel to retire and replace their sockets on a yearly basis (and possibly the Chipset too).
At any rate, the real difference in performance will only matter on a 144Hz+ display. Often times, at higher resoltions (do people still game at 1080p? Yuck) both processors fall ~10fps of another (admittedly, AMD will lose that battle in most games)
Max:
https://www.techpowerup.com/reviews/Intel/Core_i5_8400/13.html
Mins:
https://www.techpowerup.com/reviews/Intel/Core_i5_8400/15.html
@Dharwin
If you send a PM to @KSliger with your order number, they will reply back with your tracking number.
Unfortunately, there was an issue with their email client sending out tracking numbers so it's may be the only way to get a tracking number until the issue is resolved for future orders.
