Answer will come by next April/May, time to receive Cerberus-X, and let @Josh | NFC to review itAnd I don't know if you're joking![]()
I'm confused myself...I paid for my case Feb. 21, but have yet to receive shipping info. Have it shipped? What's the shipping info?
Lol ..They didn't go through automatically, so I'm still waiting on the tracking numbers to be manually compiled and sent to me, but at this rate you very well may receive the case before I have tracking.
I remember seeing this case a while ago an thought it would be a rather perfect replacement for my old mountain mods bob slay case. Though only reason why I've kept the bob slay for almost 7 years is it fits inside the ikea expedit cubbies ( 13-1/8" wide by 15-1/4" deep by 13-1/4" tall" )
Though... is there a way to add some form of dust filtration to the case? Live in a dusty environment and have felines...
You can put a standard (3cm thick) at the bottom. The question is more where you can put pump and reservoir..@Aibohphobia
For the Cerberus-X, you said that there are 8 PCIe slots. The motherboard I chose (Asus Sabertooth X99) takes up 6, but 7 if you have a two slot card on the bottom-most slot. So there is about 2 slots after the motherboard, but the input headers take up about 1 more slot, so I have 1 slot to work with for bottom water-cooling. My previous plan (in the regular Cerberus) was to use a 120mm slim radiator, but now that I have some more space, I think I should be able to fit a 240mm slim radiator, and still have space for tubing (it may even be a simpler run).
Basically, my question is, can I fit a 240mm slim radiator in the bottom mount of the Cerberus X, if I have nothing in the sixth PCIe slot of the motherboard and case?
can we get a comparison of the beige Cerberus to some Noctua fans?
Mine gets here today!!Anyone received the Cerberus as of yet?
She came in 30 mins ago or so. Took a couple quick pictures, today is my wife's birthday so we're headed out. The packaging was superb, great work @Aibohphobia, KI team and Sliger!
the panel may not be fully seated. On mine it's inset slightly but it's not that noticeable like it appears in those pics.
Ahh from what I saw before it sat on top of the hole a little bit and the lip covered it all rather than it being flush to the edges.
