What did you do today?
craigbru
Cramming big things in small boxes since 2006
LOSIAS
Jul 2, 2015
343
839
What'd you decide on?
I ended up getting the Ultibot D300VS. There are so many great choices out there, but the D300VS seems to be very wll regarded lately. It's got some nice upgrades over some other printers in it's price range. Also on the short list was the Prusa i3 MK2 and the Rostock Max V3.
Soul_Est
1,536
1,928
Very nice. I am concerned as to the force of the cars on the rails as opposed to a parallel kinematic manipulator type delta like the repstrap and the LOCOOP Y.
craigbru
LOSIAS
Jul 2, 2015
343
839
Good question. Although the D300VS is a relatively new kit, there are a lot of other established delta printers relying on rails. I can't say I've heard many complain about long term issues. If so, I guess I'll adapt and deal with it. Either way, it's going to be a fun learning experiment.
Reactions: Soul_Est
TheHig
951
1,171
Just tinkering this eve.
As I continue down the rabbit hole of PC shrinking and perf/W ... I installed a xeon 1275L v3 in my Asus z97i plus. Really impressed with it so far. A quick CPUz bench turned in 1755 single thread and 7472 multi. Pretty close to the reference 4970k it lists and really close to the stock clocked 4770k it replaced. Makes sense as it is pretty much a cheaper 4770t. It has no issues with 2133 ram on this board either which is great! I plan on moving this to the Case Mod Mini when it arrives. The one issue is that I am a bit smitten with my nitro rx 480 . It cant fit in the new case so... Maybe cram a Ryzen mATX board into the Riotoro itx case seen in my Avatar? It has the space and I can roll the 480 till Vega and you know rabbit hole...
Cheers!
HeroXLazer
707
476
So are you working on a custom KB then? Will it have swapable switches assuming its a mechanical. Full layout or tenkeyless or?
It's going to be able to be hotswapped, and it's a mechanical keyboard, and it's only 40 switches. It's also going to have RGB and RGB underglow.
Reactions: TheHig
GreatestUnKnown
108
154
Today my i5 6500 arrived, I sold it on my midday break, and used the monies to buy an i7 6700...straight across only out the gas money to drive to each location but its spring in Northern California so there is no complaint here.
Also decided to expand my horticultural skills by trying to create some bonsai trees. It is strange how the older I get the more I become introspective and reconnect with my ethnic background. The attraction towards bonsai trees is because it is a long term reward/goal which requires patience, diligence, and planning. I think I will take a look at some Japanese Maples to start and then maybe try my hands at some Junipers, Cypress, and flowering shrubs...
Not only are they aesthetically pleasing they are SFF trees!
6,071
5,006
A friend of mine grows these, they look amazing. Certainly worthy of the name of "SFF trees" considering time, effort, size and efficiency !
Reactions: GreatestUnKnown
Brokoii
31
30
My neighbour's garden is full of them. he even has a Bonsai appletree.o_O
Today I got my Samsung 960 evo and reinstalled Windows. It's amazing how much faster it is than my 850evo:eek:
jtd871
1,166
851
Ordered the balance of the new parts for my A4 build. Should all arrive mid-week. Hopefully the case will be in hand by then, too. I'll set up open air to check for DOA components either way.
I won't be OCing, so don't expect to be amazed by the parts list. It will be a nice bump up from the mobile Haswell and 675m in the laptop, however.
Reactions: Soul_Est
TheHig
951
1,171
Looking forward to seeing some A4 builds around here. What parts do you plan on using?
Happy building as well!
Edti :shameless plug: I put my GIgabyte low profile gtx 750ti up for sale today on ebay and in the forum here.
7,732
Rescued my car from flooding, my city saw it's worst rainfall in some time. Some roads still closed, buildings cordoned off.
You can see my wagon is moved from pic one to pic two. Last pic is the bottom of my house under a foot of water.
6,071
5,006
I hope you don't have damage to your home and had time to save the SFF PCs ! They don't float as easily due to lack of internal air pockets !
PNP
285
257
Got to check ~300 computers to see if they updated their clocks for DST. Quite a few Windows Embedded machines never got the memo about the US dates shifting so convincing the scheduler software running on it that the network clock wasn't some malicious user was fun.
Kaiser Wilhelm is sabotaging American factories from beyond the grave.
bledha
307
268
That is quite a persistent surge, are you getting drainage or river overflow? Is your parking spot here in a problematic zone or was it just a extremely heavy rainfall? Hope all is well - glad things are elevated!
jtd871
1,166
851
i5-7500, EVGA GTX1060/6GB SSC, SF450, Cryorig C7, 2x8GB/2400, MSI H270i, 850 EVO/500GB
I'm a tiny bit concerned about the SF450 in this build as the fan is not supposed to turn often (approximate TDP for the build is 275W), but I'll probably set custom fan curves on both the CPU and GPU to be always on at low RPMs to keep the air in the case constantly exchanging. I'll start a proper log when the parts start rolling in.
Edit 3/12: adjusted capacity of SSD from 256 to 500 GB (brain farted when I wrote it)
TheHig
951
1,171
Nice!
I run the sf450 with a 45w haswell xeon and an rx 480. I find that the PSU is very quiet personally. Hopefully it is for you as well.
