sid21177
170
27
Any internal structural changes planned for the VK3 in the august release ??
If I may suggest the following
1. The sets of mounting holes on the rear L-bend can be replaced by a set of 3 slits similar to the ones on the front L-bend. That will give a lot of flexibility in terms of mount spacing
2. If the slits were close enough to the rear bend - you could give 3.5" HDD side mounting holes on the rear metal strip. One could then use both the side & bottom mounts of the 3.5" HDD to mount it vertically - 4 screws holding the HDD would solve the current instability problem for that class of HDD.
Raxe
37
36
Has Velka 5 support for 120mm AIO or 92mm AIO (Asetek 645lt) using an Sfx Psu and mini itx gpu?
Or it's possible to use a flex atx(150mm) like Velka 3, a mini itx gpu and a 92/120mm radiator? Basically reducing height from Sfx to Flex for the 92mm radiator
If not is going to be difficult to cool an i7/i9/ryzen 7 with 48mm cooler.
Btw, a great case and excellent space optimization for components!
honeybeater92
34
Hey guys,
can anyone recommend me a good pair of 2 80mm fans for Velka 3 case please? There's one video on YT that recommends this one:
Noiseblocker NB-BlackSilentPro PC-P 80mm x 15mm Ultra Silent PWM Fan - 2500 RPM
But this one isn't available in my area... Are there any other fans that I could consider using that are silent and efficient? I'm looking for the best of best...
Edit: I found 2 of these on ebay... Are these the best for velka 3 case? :D
VELKASE Michael
743
914
United States
Both are good suggestions. It is too late in the process to implement these changes. Next time, #1 can be implemented for a small ease of use improvement and #2 can be done if adding holes does not make that rear strip of metal too fragile. Rev 1.1 is mostly meant to deliver the same rev 1.0 case as before with some small improvements to the build quality (more details on that soon), so no significant structural changes have been made. There will be a honeycomb pattern spanning the bottom of the case for weight reduction, making it possible to include for free a 1) metal cover the large rear opening and 2) rear HDPLEX plate. I have yet to personally test how well these two parts work; they should be considered experimental features for the time being.
No.
It should be possible with a Flex ATX PSU and I am going to work on this later.
Hey guys,
Please note that the fan compatibility for this case is 80 * 10 mm , so the Noiseblocker 80 * 10 mm fans will not fit. I sell compatible PWM fans but they were probably out of stock and not listed on the order form when you came across it. They cost 21.98 USD each with international shipping (43.96 USD for two) and you can read about them in the top post now.
You can get 80 * 10 mm on Aliexpress to save money, but they will have a lower maximum speed, 2 or 3 pin connection instead of a 4 pin, and a less durable bearing. All of the 80 * 10 mm fans you will come across (including mine) have the same fan blade design and only vary in the bearing, power connection, minimum and maximum speed.
Reactions: sid21177 and Raxe
sid21177
170
27
Would be awesome to see them in rev 1.2
I was down at my local parts store and I saw there are a few 10mm options in 70/60/40mm - can we add mounting points for at least 1 such class of fan - centered in relation to the 80mm points
VELKASE Michael
743
914
United States
Do you remember which models you saw there? I would like to find out the price and whether they are 2, 3 or 4 pin fans.
sid21177
170
27
Evercool was one brand - frys electronics is the store
I know noctua has a 40mm PWM fan
Long term I would hope to see the VK5 bar+bracket system/variant incorporated into VK3 ?
honeybeater92
34
@VELKASE Michael
thank you for the suggestions ^_^ ... Any news regarding restocking the velkase 3 ? :D Can't wait to buy one yay!
Edit: Michael, are the fan dimensions that can fit Velka 3: 80mm x 80mm x 10mm ?
VELKASE Michael
743
914
United States
I will think about this. Sacrificing large ventilation holes for small mounting holes trades a little bit of performance for hardware compatibility. 70 mm fans will probably cost about the same as 80 mm fans, so I do not see a reason at this time to support them. If there is something useful that can fit at the top of the case alongside 40, 50, or 60 mm fans, then adding support for them might be beneficial.
The bar and bracket system and the VK5 needed to be changed to this two-piece flat bar and angled bar system with slots. The previous implementation did not work well in the prototype. Having a simplified version with two flat bars may be useful in a future VK-3 revision for mounting a 3.5" drive specifically, but there is no way that it will be possible to include it for free due to the added weight
@VELKASE Michael
No news yet. Expected availability is still early August.
80mm x 80mm x 10mm fan dimensions are correct.
honeybeater92
34
Great thanks a bunch! Could you also confirm to me that Velka 3 case (4L one that I will purchase) can fit GPU that is up dual slot) and with length up to 18.3 cm (183mm) ?
Thanks!
joconnell
58
I was all set on a dan case build with a 3900x and a 2080 (or similar) until I happened upon this thread again. 5ish liters sounds pretty great though if the case can do a decent job of cooling the cpu without throttling. I bought a 650w evga sfx psu and have a 1070 mini from a previous build that I was going to transition over into the smaller case so might just pick up the amd and an itx mobo, @VELKASE Michael I don't suppose you've gotten your hands on any of these cpu's to see what they'd be like in the 5? I take it the 3 with something this hot and a 2070 super instead would be a pipedream?
VELKASE Michael
743
914
United States
I think I will pick up a 3900X after it becomes readily available at retailers. That may be a month or two away.
If the 3900X runs at about the same temperature under load as the 2700X, it will be possible to cool it with an L9a and two of the VF-8010-PWM case fans at high speed. The VK-3 case itself does not have a great negative impact on cooling, so if someone makes an ITX size 2070 super that can cool itself in a typical ITX case, it will work here too.
sid21177
170
27
You only need to reduce the size of 4 holes (1 alternate size 40mm?? should be sufficient) :) - but I do agree the vent pattern will have to be rejigged
That would be fair - most cases offer such stuff as accessories. Maybe these bars can be made dimensionally same between VK3 & VK5
joconnell
58
Oh cool! So I'd have to get a different psu to fit the vk-3 pending a 2070 mini that'd fit, the only downside might be that the fan noise might be a bit louder due to higher speeds than I'd need to use in a vk-5?
honeybeater92
34
Anyone with a velka-3 build, what's it like in terms of noise?
I'm getting one soon and I will post my experiences here. My idea is that for example even thoguh I got an i5 8500, I will delid it and apply thermal grizzly conductonaut on the die + kryonaut on top oh the IHS - paired with Noctua NH-L9i. On the gpu side I will apply conductonaut + undervolt it and overclock as much as possible on lowest voltage.
I think it's gonna be veeery quiet!
Reactions: joconnell
