@VELKASE Michael
Is the color of the VK5 prototype the "black" you were considering offering on the VK3 ??
@VELKASE Michael
Oh wow that quite the optical illusion.What's your rationale for using honeycombs on the back and circular on the panels?
And that is amazing space savings, wow. I was also looking at your VK7 tentative specs and I cannot figure out how on Earth you have ATX PSU support, 71mm CPU cooler clearance and 315mm card support in 7.5L, short of using magic. Maybe too early to discuss that though.
I hope I'm not spamming this thread too much, I get excited by space savings.![]()
Yes. These photos had to be taken with my phone, so sorry for any color inaccuracies.
Not sure of what others think, but I love to see people interested in this project so frequent replies are great.
My rationale for using two different vent patterns is the following:
Hexagonal cutouts are good for increasing the open area of panels while minimizing the impact on structural integrity. Circular cutouts on the other hand cause less turbulence when air passes through.
With this in mind, having hexagonal cutouts in the back can help reduce weight to keep the shipping prices reasonable and open up for panel for passive exhaust. The air that passes through will have a low velocity so the hexagonal cutouts will not cause a noticeable disturbance. Air has the highest velocity near the tips of the fan blades which is at the side intakes and circular cutouts can be used there for slight noise reduction, especially for graphics card fans which will always be positioned close to the side panel.
Regarding ATX support in the larger variant, it is not too much of a stretch. SFX PSU dimensions are 100 x 125 x 63.5 mm and ATX PSU dimensions are 140 x 150 x 86. It will be difficult to visualize without a picture, but if you take the previously given VK5 prototype dimensions of 174 x 109 x 301 mm, add 23 mm to 109 mm to add PSU thickness (this is what increases 48 mm CPU cooler clearance to 71 mm), and add 25 mm to 301 mm to add PSU width clearance, you will get 174 x 132 x 326 mm (7.49 L).
Out of curiosity, have you tested hexagonal vs. circular vents for the side panels? What you say makes sense, but I think the hex pattern has so much more open area that any turbulence will be negligible. Moreover, fans will not need to work as hard. I think the hex pattern is almost the same as having no panel at all. The circular pattern is also very open though, so temperature and noise differences are probably negligible. But that's just my feeling, testing could show otherwise.
Brick-less builds will only be possible with Flex ATX.
Would the 600W Enhance PSU from Z-Cases be compatible with the Velka 3? https://www.z-cases.com/product-page/600w-enhance-gold-flex-1u-psu
Do you mean the 5.5/2.5 barrel connector or the 4 pin DIN connector?Would anyone here happen to know the diameter of the cutout needed to mount the barrel connector of the picoPSU?
I think the spec sheet for the 5.5/2.5 connector can be found on one of Mini-Box's pages (click the DC power jack connector link in the downloads box). Looks like you need a 10.8 mm hole for that one? I'm pretty bad at reading these things, though.
I couldn't find a spec sheet for the 4 pin DIN, but I had to hand drill a hole to use this connector with one of my cases. I measured the diameter of this hole to be about 12.8 mm.
Very nice cases, by the way.
For the Velka 5 and 7, what's the max height allowance for the GPU?
Glad to help! The hole I drilled allows a tiny bit of wiggle in the connector, so 12.5 mm is probably just right.Great, thanks. That is exactly what I was looking for. The DIN connector has a 12.0 mm diameter, so a 12.8 mm hole diameter makes sense. I will try using 12.5 mm for the DIN because that would allow re-purposing a 12.5 mm hole needed for HDPLEX power supplies.
@VELKASE Michael you could also include cutouts for Wi-Fi antennas if you have room on that rear plate. Most motherboards now have them built into the rear I/O, but not all.
They are typically just hole punch-outs on the back panel next to the motherboard I/O shield. The Deskmini enclosure and the Silverstone VT02 both have them -- see here: https://smallformfactor.net/wp-content/uploads/IMG_4186.jpg.Do you have any examples of what it would look like without being built into the rear I/O? I am having trouble understanding where else the antenna could be if not there.
