I'm so tempted but I shouldn't until my work stabilizes after covid... Have great joy with it Jpark! ^^
He doesn’t have the other bracket installed (which normally goes in front of the PSU). I also don’t have mine installed and it seems totally fine, which is good news since maybe the 3080 FE will be ok in this case due to a vent on the other side of that rear fanHello,
I have a pre-order for the Velka 7, but I have a concern around the PSU. I recently came across this Velka 7 build using a Corsair SF750 (dimensions: 100mm x 63mm x 125mm):
The Velka 7 specifications for PSU compatibility is "SFX (not compatible with SFX-L". I bought a Fractal Ion SFX-L for SFF which measures 125 x 125 x 63.5 mm. From the above picture, there appears to be a bit of additional room to fit my PSU by my estimation, but I'm worried I might be missing something. Can someone please weigh in on whether the Velka 7 would be compatible?
This is just my opinion but a 3800X inside the Velka 3 is probably too much. A 3700X would have been a better balance. You're not really losing much gaming performance going with the 3700X. Based on your GFX card choice, I'm assuming this is for a portable gaming rig. I just don't think the 37mm CPU cooler height requirement will ever be able to adequately cool a 3800X. You want to try and keep your temps from ever hitting 90C for longevity of the chip and to prevent throttling. 3800X in a Velka 7 makes sense because you can use a Cryorig C7G or a Alpenfohn Black Ridge cooler, but being limited to the Noctua NHL9A and other super low profile coolers, I'm just not sure you're going to get those temps down any further than you're currently getting.My first SFF build ever with my shiny new Velka 3 2.0. After a couple hours of unscrewing, screwing, cramming, and smooshing, I'm in love. It's so hot. In both ways
At full load, depending on which way it's oriented, CPU hits 85-95 C, GPU 68-76 C. I'm using a Noctua NH-L9A, Ryzen 3800x, Gigabyte Aorus x570i, and Gigabyte 2070 mini itx. I've tried reducing voltage for the CPU but all it seems to do is lower the clock speeds and the temps stay about the same. I can point a little fan at it and it'll trend toward 85. Is this about the kind of temp I should expect out of this or should I be looking into reapplying thermal goop, expanding that side of the case, or trying a different heatsink/fan?
I'm not married to the 3800x, it's just what I had handy and figured I'd "get by" on it until Zen 3 comes out. I had a spare from when I was trying to figure out what broke on my big rig.This is just my opinion but a 3800X inside the Velka 3 is probably too much. A 3700X would have been a better balance. You're not really losing much gaming performance going with the 3700X. Based on your GFX card choice, I'm assuming this is for a portable gaming rig. I just don't think the 37mm CPU cooler height requirement will ever be able to adequately cool a 3800X. You want to try and keep your temps from ever hitting 90C for longevity of the chip and to prevent throttling. 3800X in a Velka 7 makes sense because you can use a Cryorig C7G or a Alpenfohn Black Ridge cooler, but being limited to the Noctua NHL9A and other super low profile coolers, I'm just not sure you're going to get those temps down any further than you're currently getting.
Did you use Noctua NT-H1 or NT-H2 thermal paste, or something else? Also, if you're adamant about running a 3800X, you could lap the CPU and possibly get lower temps. The base of the Noctua Coolers is usually very smooth, so probably no benefit in lapping that as well. YMMV.
For people talking about cooling issues with the 3080 FE in V7: I was gunna get one prolly and revise the psu so the psu sucks air from the 3080 bottom fan, and otherwise only cables that should be blocking are like Mobo, CPU, and 2x graphics plugs if u have no sata ssd
as for temps I have:
84C 2080FE max
74C max Ryzen 2700 (3.8OC 4 cores disabled)
XC3 black protrudes friom below the metal slots by about 4.2mm, others by about 4.84mm. EVGA reps info just told us that the backplate is 4.2mm thick which is irrelevant. Compare the pixels of the pics of the metal slots and you can see the protrusion.If it is indeed 40.9mm, though, will it fit? I think the figures above were quoted from an EVGA rep on their official forums, so I expect them to be trustworthy. (Also, what does "side panel offset" mean?)
I guess this wont happen unless you were lucky to get your hands on the FE... there are no other 3080 that will fit velka as of now which IMO is pretty shitty
Just finished building my Velka 5
It was my first time building a SFF PC and it went better that i anticipated.
The actual building took me 45 mins.
Parts used:
M/B: MSI MPG Z390I GAMING EDGE AC Link
CPU: INTEL i5-9600KF Link
CPU COOLER: CRYORIG C7 Link
TIM: Thermal Grizzly Conductonaut Liquid Metal Link
RAM: CORSAIR VENGEANCE LPX 16GB (2 x 8GB) DDR4 DRAM 3000MHz C15 Link
M.2: XPG SX8200 Pro 1 TB Link
M.2: ADDLINK S70 1 TB Link
PSU: CORSAIR SF600 — 600 Watt 80 PLUS Gold Link
GPU: ASUS Strix GTX 980 Link
Preparation:
I re pasted the GPU with Conductonaut
same was used for the CPU
Assembled everything outside of the case (obviously),
Fitting components in the case was pretty strait forward, cable management was fairly easy (for the size of the case)
My main issue was with the fitting of the GPU, a it is quite large, even after the installation of the optional brackets, bottom fan was still scraping in the cover
i had to stick a double sided foam tape on the GPU cooler to gain 1 mm of extra clearance.
Temps & Noise
Ambient temp: 24 C
Idle:
GPU: Temp: 30 C, Fan speed: 0
CPU: Temp: 37 C, Fan speed: 30% (min that can be set in M/B)
PSU FAN: 0
Noise: inaudible
Stress test GPU & CPU (GPU stock)
GPU: Temp: 67 C, Fan speed: 38% (178W)
CPU: Temp: 78 C, Fan speed: 100% (all cores at 4.3 Ghz / 75W)
PSU FAN: Running
Noise: Only CPU fan is audible, but not very loud or annoying (42 db)
Stress test GPU & CPU (GPU +100 Mhz core, + 200 Mhz memory)
GPU: Temp: 68 C, Fan speed: 42% (187 W)
PSU FAN: Running
Gaming (GPU +100 Mhz core, + 200 Mhz memory)
GPU: Temp: 68 C, Fan speed: 40% (187 W)
CPU: Temp: 55 C, Fan speed: 50% (all cores at 4.3 Ghz / 60W)
PSU FAN: 0
Noise: Only CPU fan is audible, but not very loud or annoying (38 db)
Photos
I have a problem with my Velkase 5 rev2. My 24 pin tab is preventing the front panel from fully closing.
I tried removing the I/O Shield but it's not enough. I also tried to buy a 30cm 24 pin extension cord () and shave off the tab but then the longer cable wouldn't fit inside the case. Can anyone suggest anything other than cutting/sanding the tab?
Many thanks!!!
