Made an account just for this case. Very excited, but I'll have to find a low profile x99 cooler. Super stoked to find a case that checks all my boxes.
Thank you and I'm really glad for that!
You can check out dynatron coolers:
R30 | Dynatron
_______________________________ CPU SUPPORTIntel CPU SOCKETLGA2011/2066/SQUARE APPLICATION2U MAXIMUM POWER165W_______________________________
www.dynatron.co
R15 | Dynatron
_______________________________ CPU SUPPORTIntel CPU SOCKETLGA2011/2066/SQUARE APPLICATION1U MAXIMUM POWER165W_______________________________
www.dynatron.co
You can mount bigger fan to them, 25 mm thick one, and you can put 60 mm fans on top to pull out hot air and that combination should work fine.
Also, you can consider id-cooling is-50:
39.99US $ |Id-cooling Is-50x V2 Tdp 105w 55mm/2.17" Height High Performance Low-profile Cpu Cooler For Mini-itx /htpc System - Fans & Cooling - AliExpress
Smarter Shopping, Better Living! Aliexpress.com
ID-Cooling Announces IS-50X: 130W, Low Profile CPU Cooler
ID-Cooling Announces a 130W TDP capable low profile CPU cooler, the IS-50X.
But I'm not sure if i comes with mounts for socke 2011-3, maybe you could hack something. Also, it's 2 mm to tall, but you can either squish it a little bit, or use 120x12mm fan instead of 15mm thick one.
Or, of course use an AIO if you have nothing else in that space.
