Completed SFFtime presents: P-ATX, the 9L case with ATX and AIO support!
riba2233
2,000
2,608
Croatia, EU
www.sfftime.com
Starting to look at parts, though it might be a while before I start the build proper. Any compatibility issues with below? Particularly GPU, which is 2.3 slot. Will likely go with a true 2 slot 1660 Ti or Super if so.
Case: SFFTime P-ATX (obviously)
Mobo: MSI B450M MORTAR TITANIUM
CPU: Ryzen 3600 or 3600X
HSF: Cryorig C7 Cu or G, with different fan (Noiseblocker BlackSilentFan XE-2 or GELID Solutions FN-FW09-20-B)
RAM: Team T-FORCE NIGHT HAWK Legend RGB 16GB (2 x 8GB)
SSD: 256GB NVMe (have) + Team Group T-FORCE Delta Max RGB SSD 2.5" 1TB
PSU: Fractal Design Ion SFX (SFX-L) or Seasonic SGX (+custom sleeve cables)
GPU: Sapphire Pulse 5700 (non-XT)
Case fans: 4x 60mm Noiseblocker NB-BlackSilent Fan XR-1
(Parts are flexible at this point - many chosen for aesthetic reasons, at least in part)
Yeah, gpu is too thick. I would recommend powercolor red dragon, or regular two fan powercolor if the red dragon is not available. (2 slot strict with motherboards larger than itx)
Also, the 4th case fan, the one on the bottom is too thick, it should be max 20mm. But it's actually not necessary, especially if the gpu has vertical fins like red dragon does.
Any more precise ETA for this case? Any new pictures? :)
Well I just picked the parts from the anodization, so I just need boxes, and they should be ready early next week. Then I will also get professional pictures with assembled units ?
wertigon
54
33
Interested in this build, two questions;
1. What would you charge to ship to Sweden?
2. Would that price be lower if me and a friend of mine ordered multiple cases?
duynguyenle
331
331
Thats good news. Where do I leave my fat stacks of money?
Reactions: CountNoctua
riba2233
2,000
2,608
Croatia, EU
www.sfftime.com
I'm ready to throw my money at you bud
Just a few more days just, I will open webshop on Monday (hopefully) or Tuesday ?
Thank you, here are the answers:
1. For one case around 26 USD.
2. Yes but not to much, I can ship two cases in one package and in that case it's 36 USD for two cases. Three cases 62, four cases 72 etc.
MrClippy
126
143
Starts refreshing the page every 20 minutes
Reactions: riba2233
riba2233
2,000
2,608
Croatia, EU
www.sfftime.com
Hi guys, sorry for the lack of the updates. I wanted to get some things sorted out before posting.
This weekend I have discovered something really disturbing, the powdercoating on the side panels turned out horrendous, and I'm not exaggerating even a little bit.
Yes, it was my mistake that I didn't check it right away, but trust me, I have never seen something like this, and I just didn't expect for this to even be possible. Here are a few pictures:
All of the panels were like that, not even a single perfect piece.
So I went to return them yesterday, and the manager agreed that this is a disaster and they said that they will fix them by Friday. They were pretty fast the first time, so I hope they will be again.
That said, anodization looks fine, here is one test assembly:
Other updates, boxes should be ready by either Thursday or Friday, I just spoke to them, and I have packed all of the case accessories.
Here are the pictures with weights:
In total it's 2.8 kg.
Regarding website, I just need to ad cookie policy, and I plan to launch it this afternoon, but I wont allow buying since I want to see how the panels turn out first, I hope you agree with me on that one.
SpringerTheNerd
195
209
32
Seattle WA
Looks absolutely fantastic. It's too bad about the coating failure but as they say shit happens ?‍♂️. Thanks for updating us. Hopefully it's a quick turnaround! I'm eagerly awaiting my chance to put my order in!
Reactions: riba2233
riba2233
2,000
2,608
Croatia, EU
www.sfftime.com
Thank you for the support! Yeah, I was really pissed when I saw the panels. If only there were a few perfect ones so I can at least ship a few cases.
Reactions: SpringerTheNerd
duynguyenle
331
331
Thanks for the update. Pity about the panels, I have had some similar issues in the past with powder coated parts, and sometimes they stem from impurities in the spray nozzle or defective nozzles. Sometimes it could also be improper handling of the parts.
Hopefully you can get the shop to sort this out on their own dime (it is their fault after all)
Meanwhile the rest of us will wait a little longer
wertigon
54
33
Whoa, it even turned out better than I thought it would! Bummer about the powder coating but rest look seriously great!
Hoping this run lasts until January, if all goes well my financial situation will allow me to pull the trigger on the case by then! This is one of my top contenders, great work! :)
