Prototype [Scratch Build]Project REAL CUBE (Back online, V3.0 soon)
Minefoxi
146
68
www.youtube.com
Some new renderings of version 2.0 before ordering the panels ;) (I finally chose a much more realistic texture for the panels and switched the background color to a light grey)
Stay tuned, it's going to be awesome and I'm so looking forward to it right now
4,793
Looks good!
I would recommend doing renders like that in perspective mode though. People who don't use CAD programs aren't used to parallel projection so it looks funny.
6,073
5,006
Is that a different type of wood for v2.0 ? It seems to have a more consistent color and texture. Also the lasering looks to be better, is that QinX's new support frame in action ?
QinX
kees
Mar 2, 2015
541
374
It's the same wood but I've pre-sanded it before cutting, also I'm getting more familiar with the machine.
What do you mean with QinX's support frame? I've only done the cutting for Minefoxi, everything else he has done himself :)
6,073
5,006
About the support frame, I read somewhere in this forum the burn marks at some of the sharp edges were due to the laser intersecting with the hexagonal support frame you use below the material for the laser cutting and you were going to try a new one.
Minefoxi
146
68
www.youtube.com
Thanks for answering my questions lol ;)
7,736
Nice work :) I have a question though - how much work would it be (for example if I was to get a laser cut wood case made), to sand down the carbon and get back to clean wood?
Minefoxi
146
68
www.youtube.com
Thanks ;)
About the clean wood: I think you'd be better off CNC cutting it :D The carbon is only a thin layer though so I'll come off quite easily. At the moment I'm rather trying to keep it as good as I can though :D
QinX
kees
Mar 2, 2015
541
374
Sanding down the carbon to exposes the natural wood depends a lot on thickness of the wood and the design. A simple rectangle can be sanded by hand with ease, but more complex shapes, especially those with inner radii are a little trickier.
Thanks ;)
That is a major advantage for CNC milling, no charring whatsoever, the one thing to take into account is that have actual corners is difficult/time consuming. You either need a tiny mill or be able to mill on multiple axis. Also lasercutting in general is a cheaper process, setup times are a lot lower, the programming of the laser tends to be very low and no tool swapping is needed. both have ups and downs ofcourse.
I've not needed to sand the sides parts I've used, but I thing instead of sand paper an abrasive pad might also work, something slightly more abrasive then a toothbrush would work great without damaging the wood too much.
7,736
Thanks for the info. My aim in questioning was to get the wood cut my machine as cheap as possible but end up with that 'hand-made' look and feel :)
QinX
kees
Mar 2, 2015
541
374
This will be my last bit of info in the topic, don't want to hijack Minefoxi's thread too much ;)
I'll see if I can whip up a small example to show off in my KogelMier thread.
