Thanks
About the clean wood: I think you'd be better off CNC cutting itThe carbon is only a thin layer though so I'll come off quite easily. At the moment I'm rather trying to keep it as good as I can though
If you want really clean cuts but at laser prices get it abrasive cut at a waterjet. Just make lead-in lines to your drawing, as the stream needs to start up and will splinter the wood. Once it has punched through, then you will get clean, beautiful lines...and no burn marks!
