I'm a little concerned about the p-shaped piece. You will be using Plywood for this, right? It should be fine as long as the PSU doesn't put too much pressure on it.
I don't know how many of you still remember it, but I hope that some are still interested in the progress I've made over the last year (during which I also started studying mechanical engineering)
For now, I updated the first post and I'll just leave those fancy KeyShot renderings of Version 3.0 here:
Not much changed on the outside...
...except for half the screws on the back beeing gone or moved somewhere else now
On the Inside however pretty much everything but the general hardware layout changed
In my V2.1 build, I currently haven't even put in that part, but with the PSU screws, the support beam on the right and with sitting on top of the two 70mm fans there is enough support to keep the `PSU support plate´ horizontally (you even really need some force to bend the front right corner of the PSU down, just tried it )
That will probably not happen, but it already looks really cool when you have the right panel taken off and look inside with the Noctua tower cooler taking up the whole space between motherboard and PSU support plate.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
