Prototype REVOCCASES RCC-SMALL3 | 2.65L brickless ITX case & optional 1.56L Thunderbolt eGPU
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
Im moving my rig into a sandwich style case and have the same mobo and cpu as this. I have about 55mm of clearance so im looking at the axp90 x53 cooler. What are some of your bios settings to keep this beast tame?
Not sure if what I did was the best way to make it work but here you go:
first I changed PL1 and PL2 both to 125W and did a Cinebench run, observing that temps would reach 100C very fast.
next I discovered a MSI BIOS feature called "CPU Lite Load" which was set to Mode 9 out of the box. Every mode has some factory pre-settings for CPU voltage curves. I started to set lower modes step by step until Cinebench started crashing. For me that was Mode 5 and it lowered temps quite a lot.
With the thermal headroom gained with CPU Lite Load I then started to increase PL1, PL2 and PL2 duration until I found the right balance (for me) between performance and CPU temperature.
Hope that helps...
Reactions: KindColt and morj
