Log RCC-eGPU2 | a tiny portable 0.6L Thunderbolt GTX 1650 eGPU
antoniopop123
I edited my post but I think I understand what you are trying and it does work in other scenarios (ITX with one psu for board + 2nd psu for card 8pins)
Kind of expensive just for a test but definitely worth it if it works. It could enable some extremely small external psu builds with the slimq gan charger.
FlexxRocket
I tried to Build my own mini eGPU But it doesnt get detected as gpu only as Media Drive i connected the pcie to m.2 to TB3 Adapter and the Card Makes noises. So Could you help me here?maybe in bios?
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
I am using this realtek RTL9210B i bought from aliexpress and i connected it to 2021 Hp spectre x360 with Intel Iris xe and i71155g7 (13,3 Inch)
That doesn't work. You need a real Thunderbolt (40Gbps) compatible M.2 adapter/ SSD enclosure. They usually sell for around 100 bucks.
For example:
