Log RCC-eGPU2 | a tiny portable 0.6L Thunderbolt GTX 1650 eGPU
1,254
If possible, could you show me the exact wiring structure of the picobox power supply in a picture?
Luckily I happened to have it in a box in the cupboard - unfortunately the connectors had been stripped since last I used it.
As such, please do not judge me on the twisted/taped wires 🤣
Both connectors are wired with the positive voltage TOWARDS the clip as below:
milesvw
158
109
Use two of these 12v battery holders (in parallel).
Then this two pack of 6 Ah batteries with a charger
If using this I would suggest an "ideal diode" Mosfet board. It basically switches to whichever battery has higher voltage. https://www.aliexpress.us/item/3256806118206706.html
Better yet may be a battery bank that will output PD 12v. Or a DIY version using 18v battery packs and a 'Solar' 100w PD power adapter and a PD trigger to get 12v. Then the voltage will be stable.
https://www.superbuy.com/en/page/buy/?url=https://item.taobao.com/item.htm?id=684086754983
https://www.aliexpress.us/item/3256805813121586.html
I would probably solder onto the board and just plug the male USB trigger in to signal 12v output.
jhines97
I don't really understand what you are linking to. I also figured I might need a voltage regulator like this one. (given the varying voltage from batteries) https://www.amazon.com/gp/product/B078Q1624B What do you think?
REVOCCASES
REVOCCASES
2,237
3,652
www.revoccases.com
codearm2
Not sure... I don't know which PINs of the 24P connector are actually used / required on that board. I assume only 12V, GND and PSON but it's a wild guess...
the pins marked with orange marks are needed
Do you have any idea how to do it using pico psu?
codearm2
the DCDC200 is a step down converter and only provides +12V and GND.... no 3.3V, 5V, PG, PSON, etc... if you need those PINs connected, you have to use a "normal PicoPSU"
Alright, understand
Btw what if I want to use my 20v5a Gan charger to power up the 12v input "normal pico psu" (I can't find any normal pico psu that can take 20v)
Can I use a decoy to trick the gan charger to output 20v, then drop it down using a step down to 12v while retaining a full 100W? My card itself is 6400 so it will use around 50-60W
REVOCCASES
REVOCCASES
2,237
3,652
www.revoccases.com
unfortunately there are very few reliable wide voltage Pico PSUs these days since HDPlex stopped production of their unit
might work for the 6400, but I think it's not worth the trouble... doing my napkin math, that setup will end up more expensive (and larger) than just buying the EXP GDC OCuP4GaN (which I have btw, and I'm pretty happy with it)
codearm2
Bought it!
thanks for the recommendation
Zaza
m2 dönüştürücüyü thunderbolt ssd kutusuna bağlayıp güç kaynağını GPU'ya bağlarsam çalışır mı? Ekstra hangi işlemler var?
MOD EDIT:
If I connect the 76m2 converter to the thunderbolt ssd box and connect the power supply to the GPU will it work? What extra steps are there?
7,736
@Zaza Please post in English as per the terms and conditions you agreed to when registering.
Bungbung123
Hi there im very new to this and im wanting to use the dcdc200 with a rtx 5060lp. Ive seen that they use around 150-160w which would work with this but the problem is that I would need to power it with an 8pin cable. Trying to keep everything low profile, I found this cable that i thought might work with powering the gpu but im not entirely sure. Its got a cpu 8pin that goes directly to a gpu 8pin. Any help on this would be really appreciated.
