Concept TIPIO2 - dedicated GPU and internal PSU in <2.9L
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
somebody asked me if it would be possible to make a similar case like my TIPIO1 but with internal PSU and <3L volume...
Unfortunately I am currently busy with other stuff to turn that into an working build, but maybe I'll follow this up when I have some free time...
Possible specs:
  • 250mm x 190mm x 55~60mm
  • 2.65L ~ 2.85L
  • Thin Mini ITX PIO Motherboard (e.g. JUBO H310C-G)
  • Low Profile, Dual Slot GPU (currently up to GTX1650)
  • HP 12VDC, 200W AIO internal PSU
  • JONSBO HP400 (or similar) low profile cooler
Details / Layout:
Suitable PSU:
Suitable PIO Motherboard with internal 12VDC input:
Suitable GTX1650:
Reactions: robbee and Goatee
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
Does the psu not block the mobo power input though?
You are right - that's why I haven't fixed the case volume yet - probably have to get a little bit creative there but it should work...
as a side note, my board came without that connector soldered on - so I would probably solder a 4P pigtail cable to the board to make the case as slim as possible
