Production Nouvolo Steck - SFF 8.7-11.2L ITX PC Case, supports liquid cooling
Hifihedgehog
Editor-in-chief of SFFPC.review
May 3, 2016
459
408
www.sffpc.review
I mean, if the temps are under prime at 3.7ghz around 85 degrees with the 2700X and the L12S, why not with the 9900K?
The reason being is the 9900K runs even hotter. You will thermal throttle or even experience thermal shutdown. An AIO is basically required unless you downclock it or you manually lower its target TDP in the BIOS.
Allhopeforhumanity
548
539
Denver
Thanks man for this update!
Could you try the first scenario, so no fans above, panel on, and the CPU fan in EXHAUST, pushing air through the radiator to the outside???
Just to clarify: You'd like me to try no top hat, and L9i pushing air out of the side panel instead of pulling in?
That gives me another idea too; when I get the 15mm fans, I'll try 1.) bottom intake/CPU cooler exhaust, 2.) Top intake/CPU Exhaust.
fabio
1,885
4,325
Exactly that!
And in your case as well, Intake from the L9i, and exhaust bottom or top.
Reactions: Hifihedgehog
Hifihedgehog
May 3, 2016
459
408
www.sffpc.review
Maybe I have designed a Porsche here
Actually, I thought it was a Bloodhound SSC. ;)
Reactions: Allhopeforhumanity
Hifihedgehog
May 3, 2016
459
408
www.sffpc.review
I have a simple mod to share. I just got my MonsterBolts M3 screws that I had ordered through Amazon ( https://www.amazon.com/dp/B07981X3QQ/?tag=theminutiae-20 ). They are far and away much better quality than the stock screws. The stock screws’ slots bow and wear very easily. These are much more smoothly formed, premium looking and strong and sturdy. They actually screw in more smoothly and firmly as well. See here.
Stock:
MonsterBolts.com:
dumplinknet
364
168
Fir
Stock:
MonsterBolts.com:
First of all, you're using the wrong stock screws. You need to use the flat headed ones for this area. There only 4 flat head screws that come with the case. The rest are round heads.
With that said, the stock flat heads fits perfectly, in that they sit recessed with the hole and the panel. The Monsterbolts one above looks like they sit above the panel- thus the top panel won't sit perfectly flushed.
macbosco
304
710
www.nouvolo.com
I have a simple mod to share. I just got my MonsterBolts M3 screws that I had ordered through Amazon ( https://www.amazon.com/dp/B07981X3QQ/?tag=theminutiae-20 ). ...
I have counted wrongly and may have not included enough flat head screws. But I will pack more of those in the future. Use round headed screws wherever you don't need to fit flush with the surface. And in any case, those screws are really ubiquitous, with easy modding and finding extras/replacement in mind.
Hifihedgehog
May 3, 2016
459
408
www.sffpc.review
Fir
Actually, these are the stock flat ones. The round or bulbous-shaped ones I use solely for the feet and the motherboard mounting. As you noticed, though, the stock flat M3 screws are not as perfectly flat as the MonsterBolts ones I just received. These MonsterBolts screws so strong and precisely formed that they actually grip firmly to the screw driver bit. Very high quality. I highly recommend them. I can try taking a side profile shot later so you can see that I am indeed using the appropriate screws.
macbosco
304
710
www.nouvolo.com
OK, fixed my rig once again with NH-L12S passive cooling and added a 120x15mm fan. Gotta play some games first, will do testing later today or tomorrow :). Just to show you guys the 120mm fan fits perfectly, still using Corsair PSU stock cables, lots of room to spare for the fan, normal rev at ~800-900rpm (web browsing). Can feel a cool breeze pumping in there, will see with tests later, but so far it feels good.
EDIT:
Test results - Prime95 small FFT 10min
  • System : Ryzen 2 2700x, Asus B450-i
  • Cooler : Noctua NH-L12S (pull out)
  • Chassis fan : Noctua NF-A12x15PWM (bottom, push in)
  • All panels closed
CPU temp (idle / test) : 51 / 84 degC [ 79degC with CPU side panel (only) opened ]
CPU cores speed (idle / test) : - / 3.7GHz [ stock ]
CPU power draw (idle / test) : 27 / 129 W
CPU fan speed (idle / test) : 810 / 1849 rpm
Chassis fan speed (idle / test) : 783 / 1753 rpm
I think the bottom fan helps A LOT! This will be official recommendation for stress test condition for i7/2700x config. And I think that under "real life" usage it should seldom reach such loads. Putting on the cover adds about 4-5degC.
fabio
1,885
4,325
I did it: Intel 9900K:
all AUTO in the ASUS bios, only Multi Core Enhancement DIsabled
Ram XMP Profile at 3200 CAS14
Nvidia P5000
Noctua NH L12S in Exhaust
Custom panel
To mount the L12S on this Asus, I've removed the I/O shroud and replaced the VRM heatsink with the full copper by Enzotech.
It's insane!!! Intel did a GREAT JOB!
Under Prime95, 3.6GHZ ALL CORE, 95W, 65 Degrees MAX
Under Real Bench stress test: 4.2GHZ ALL CORE, 98W TDP, 75 Degrees MAX
Intel Burn Test: FROM 4.7 TO 3.9 GHZ CONSTANT, 97W TDP, 65 Degrees MAX (70 degrees CPU Package)
I've found my FINAL SMALL WORKSTATION!
Enjoy!
loader963
665
571
Va
Agreed. This is already solid start to an excellent product line. Line upon line, little by little as they say.
By the way, I will be publishing the Corsair H100i RGB Platinum performance results later today. The bottom line is there is an approximate 10-15 degree temperature improvement with this AiO.
Quick question: if I purchase on CableMod, what lengths of custom cables should I order for this case? I have an ASUS ROG STRIX X470-I GAMING. I have never purchased custom cables before. Besides the motherboard power connectors, I will need (2) eight pin power connectors for my video card, (1) SATA power connector for an SSD on the lower 2.5” drive mount, and (1) SATA power connector for the Corsair H100i RGB Platinum AiO. At least some tips in ensuring the proper lengths would be helpful. Thanks!
Or you can order this, should be ok!
The problem with CableMod is that you cannot go under certain length! But should be ok!
https://www.pslatecustoms.com/collections/louqe-ghost-s1-cables
Side note here: I’m late to the party but cable mod will make shorter cables on request. I had to email them before purchase and ask them. Then after purchase I detailed my lengths and they took care of me. And pslatecustoms looks like they are awesome but haven’t had a chance to use them yet.
Edit: firsthand experience as they did the cables in my Cerberus x and was very happy with the results.
fabio
1,885
4,325
Cool! Didn't know that!!! Thanks a lot @loader963 !
Reactions: loader963
loader963
665
571
Va
I did do my lengths in increments of 25mm, don’t know if I had too, but that was close to their configurator settings, was very happy with it.
Longbow072
92
50
United States
Sent off my case in prep for BF purchase. Since i'll have to ship it home from work I'll keep it ACed now, then order up the AIO either on BF if the deal is right or after I get settled in my new job/place.
