Production No more sandwich. W19. Up to 360AIO and custom loop. Up to full size 3-slot gpu. DDC pump. Ready for uncompromise watercooled in 10.5L console case.
Which kind of case to send to production first?
  • Total voters
  • Poll closed .
osin17
Hello,
I'm following every day this topic to get any news on delivery date. More than 2 weeks since last post from @SammyXXM . I hope everyone still safe.
Vir
72
61
Something might be going on with the war in Ukraine ?
It's been stated previously that manufacturing was based in Ukraine, and that Sammy is trying to move production to Moldova.
None of us know how the war has affected the business or the personal impacts of it.
While the lack of response may be frustrating, like, yo, people might have friends and colleagues in a warzone. The chance of there being legitimate excuses is high. Wait just a bit longer before calling a scam or dishonesty.
mike1104
I was really looking forward to this and was gonna order if production was a bit faster. Theres a new case from Sliger called the Trego that seems very similar to this any1 seen that one?
mike1104
It looms relatively thicc compared to the w19 tho
Houdini
156
82
I personally don't like the design of the Trego, but apart from that it's 22L which is 2x the W19 😅 and the "features" you get in return are so not worth it IMO.
The only other case I'd consider (right now) is the Sliger SV590 v2. 18L, has 360 and even 420 rad support but is also expensive
Reactions: mike1104 and sos
idgas
21
I'm a Sliger fan but wouldn't compare the cases here as they target significantly different audiences.
Whoa, did I miss some drama? Hopefully by now everyone knows what's going on in the world, and anyone who's preordered knew what they were getting into.
SammyXXM
230
387
Moldova
anthecase.com
So, the first batch has arrived. But the problem remains with the side ones, I ordered them in China :( I'm trying to do it At local factories, they promised a sample this week.
Cheezo
52
24
Waiting for this case and FormD, and looking for 240aio for this.
found old imgur in this thread, looks like asus lc240 best for me - will fit in new formd 100%, but still not sure about W19 :(
Btw i sold my FE gpu and have asus strix 3080 - it's 3.25 slot, so looks like i will can't use it?
Houdini
156
82
if this spreadsheet is correct, then I would say all AIOs can fit the W19 if the waterblock height is <47.9mm.
But keep in mind that depending on your motherboard (without modifications like taking off M.2 cooler) you might need to angle the tubes at the waterblock upwards which can result in >47.9mm height
Houdini
156
82
GPU size up to 330x130x63 (in 240 mode or air cooling mode) or 215x130x63 (in 360 mode).
Asus lists 318.5 x 140.1 x 57.78 mm as size for this card so I think it can not fit, not because of 3.25 slot but because of height. But @SammyXXM needs to confirm
Edit: It might be that the 140.1 height is including the PCI bracket, in that case it might be fine
SammyXXM
230
387
Moldova
anthecase.com
Here is scheme of the allowable GPU thickness as viewed from the bracket side and using the protrusion of the first bracket as a reference:
