Stalled [New Video Assembly] Densium 4 & 4+ - Tiny cases with real hardwood frontpanel!
Densium.net
191
309
@Densium.net: How precise are the dimensions of the Densium 4 on your website? The reason I'm asking is that I'll have some time on my hands the next two weeks and I'm anxious to start with my custom front panel ;) Can I rely on the dimensions on the product page or would you say it's better to wait for the case to arrive?
Check the attached PDF file
  • customfrontpanel.PDF
Densium.net
191
309
You're amazing! Thanks so much. Let the fun begin :D
I just have to warn you; The button wont be compatible with a thicker front panel, so if your panel thickness will be >8mm you might have to use glue for your button, or source a new button with longer threads yourself! Other than that, you can just go ahead! Looking forward to seeing your custom front panel!
mikefize
31
48
Thanks for the heads up. I think it's gonna be fine, as my "front panel" will essentially be hollow to accomodate the I/O, the Card readers and SATA SSDs. So the real front is likely going to be 1.5mm :)
When I'm at the point to worry about the button, I will be more than happy, haha. Some pretty big challenges ahead.
Reactions: Densium.net
Densium.net
191
309
Sounds good - I wish you the best of luck on your little journey, hope it works out great. Take care
Reactions: mikefize
Bakaban
122
111
Thanks for another update Densium (march 11th). I'm perfectly OK with the proposed screw selection and solution. Cheers man!
Bakaban
122
111
For everybody who is looking for a first look at the FX600 from SilverStone:
Unboxing is online and the first short Sound-Test is already done and will be uploaded this week. :)
It seems DinkieTheSink also got his hands on the fx600 for a review: Looking forward to your take on the psu. He mentions an intersting observation about the increased 24pin cable lenght and the odd double eps-connectors. Curious to your thoughts on this.
GucksTV
249
510
www.youtube.com
hey guys! :) I just want to let you know that my review samples arrived and I've been able to take a closer look at both the Densium 4 & 4+
I don't know why but I can just insert the album from imgur, maybe there are to many pictures: https://imgur.com/gallery/GKJPZ0z
I am shocked (positively) how well the cases have been made. They are sturdy and rock solid. Quality is probably on pair with Velka and with way less screws! :D
The design is stunning and the wood is really something else...I love it! In my pictures I've got a Black painted wood Prototytpe by Audun aka @Densium.net and it looks very nice aswell! Even when I love the look of that walnut wireless-charger next to the Mini-ITX Case! <3
The Low Profile Power Button is a very nice implementation. Better then the competition.
I really like the fact that the Densium 4+ actually gives 220mm GPU clearance while staying at 4.9L volume...
And obviously I have to show it to you guys...the MSI RTX 3060 Ti AERO ITX in all its glory! <3
I will build a system inside the cases during the next days, and have some FLEX PSU testing planned.
Otherwise I will make a Giveaway of the white Densium 4+ after my content is done and will add both PSU and CPU Cooler to the package! :)
So stay tunned for my content!
