Moving this back the the M1 to better cool the GPU. Not really working so far. It’s still running at 80c. I have more work yet...
Thank you for sharing!Results from tests here.
I should have tested the normal orientation with extra back exhaust (90mm).
Don`t have the system anymore. =(
Switched to C14 with 5x Noctua A12x25 fans. I’m stubborn about not having any exhaust blowing at me, so both the left (front for me) fans and bottom fans are set to intake. Rear A9x14 fan is set to exhaust. Also elevated the case slightly with the Cerberus feet.
I think the U9S might be dissipating heat faster than the C14.
Yes. If I switch the bottom fans to exhaust, I would probably get better CPU cooling.So, you are using 2x NF-A12x25 fans as push-pull for the C14?
Is there a reason you do not use 2x NF-A14 fans?
I think hot air is not being exhausting out of your M1 fast enough, with only one exhausting fan (A9x14).
So, air exhausted through the C14 in all direction is unable to be extracted out quick enough, resulting some of them to be recirculated back. As for the U9S, the air exhausted through is already lining up in the direction of the rear exhausting fan, thus it is more happy than the C14.
No worries! With the windowed panel, the CPU and motherboard VRM runs hotter as expected. I only checked CPU temperatures at first, but started noticing VRM throttling with the Strix Z390i heatsinks removed (to fit the C14 or C14S). CPU ran about 5-10c higher. No data on motherboard temp other than it was throttling the VRM.Sorry @Nanook you have done so many configuration changes I can't keep up, how does this setup compare temp wise to the window panel?
Played around with some overclocking:
UEFI settings:
MCE on
Locked boost power limit at 190w per Noctua recommendation for the C14.
Gaming boosts up to 5ghz
Torture tests boosts to 4.5ghz
GPU boosts up to 2010mhz
Prime95 small FFT and Heaven running at the same time:
CPU 75c
GPU 64c
Gaming temperatures:
CPU 50c
GPU 64c
Yes, with panel closed. CPU power limit Is set at 190w.Are those temps with the side panel closed? I'm curious because those do look promising for when I upgrade my CPU (have similar cooling setup with C14). Only difference is that with the GPU bottom intake, I have the right side fan setup as exhaust for the GPU.
Thanks!! I’ll look into HWinfo v6. I may need to update it. I was relying on XTU to inform me on what’s throttling, and what’s the limiting factor (power vs temperature)The latest version of HWinfo (6.0), exposes VRM temperature readings. On the Strix Z370-i the VRM throttles at 115C. Might be different on the z390-i due to the different VR setup, but I don't have a board on hand to test with.
I tried out HWinfo, but wasn’t sure what the motherboard VRM is labeled as. I found one temperature reading that said 78c, I assume that was the VRM, as my CPU was at 100c. (running Prime95, with unlimited power limit, and throttling).Yeah I was using XTU too to give me that information, I suppose that having access to the actual temperature made it easier to determine the vCore and AVX offset at which the VRMs would stop throttling.
In my case I needed an AVX offset of 5 at 5.0GHz to run Prime95 without the VRMs hrottling. Realbench runs fine with an offset of 2. 8700K at 78C
