GPU Low Profile GPU Potential/Discussion
2,201
2,215
My SKTC A02 could easily fit 3 slot assuming there's only 2 physical brackets on the card.
Silverstone ML09 and ML06E could do 2,5 slot, though I'd prefer to stick to my "deshroud + 2 80x25mm fans squeezed between heatsink and side panel" set up that makes the card super quiet.
There are always some, which is why I said close to zero and not zero ;) It would still be a risky proposition for the maker of that GPU though, as they'd be targeting a niche within a niche within a niche. Not much money in that.
neepheid
No low profile options (yet), but it is pleasing to see there will be a couple of options in the <210mm length department - the ASUS Dual Mini and the EVGA XC. I use a Jonsbo T8 case and so while full height, 2 slot cards are accommodated, the length is limited to 210mm. Last generation, Zotac did a 2070 Super mini which was exactly 210mm in length and there were a few 2070 (non-super) options from Gigabyte, ASUS and MSI. So I'm pleased to be able to skip the 20 series (currently using a 1660ti) and enjoy 2080 Super-like performance with a choice of 3060ti cards to fit my T8. Good times, if/when I can buy one!
