One of my favorite designs. No-nonsense, but still very elegant (visible screws look great here).
I sent off my revised drawings for updated pricing and leadtime. I've included a side panel design with CPU vent, and bottom GPU vent. I will probably make this the default, and have an optional non-vented side panel. The side panel with CPU vent allows for more flexibility, and allows using the case without any case fans to a point (similar to L4), which is a nice option. Then for greater cooling, or for the non-vented side panel, one can optionally add case fans at the front.
Top down style, with top of fan at ~48 mm or less
Hi Lone, what does the 48m mean ? L12S is 70mm height
I'll have to clarify and update that.
Note the location of the fan on the NH-L12S. This places the top of the fan at 48 mm or less, and as a result has sufficient clearance between the fan and side panel.
With a vented side panel, that 48 mm could be changed to 58 mm. Actual physical clearance is about 72 mm.
The inside is an empty box.Is there a particular angle/area you're interested in?
I'm about to send my purchase order off to my manufacturer. I may not order any non-vented side panels, unless there's more than one person who really wants one. I can't imagine there's anyone who wouldn't buy the L5 because it has a CPU vent on the side panel?
Would some measurements be more useful to you?
Inside front width: 86.7mm
Inside front height (usable, without fan mounting bracket): 206mm
Motherboard to fan mount: 40.4mm
Motherboard to inside front without fan mount: 46.8mm
Motherboard to bottom of chassis flange: 30.8mm
Motherboard to bottom of side panel: 32.9mm
Motherboard to top of chassis flange: 8.1mm
Motherboard to 80x25 mm fan: 15mm (subtract 1mm for silicone mounts)
Love those thin cables for SFF. I believe I / someone has asked about these wires before.... where can I get those thin cables?Yes, I will take some more photos when I can. This is how it sits right now.
Note, the next batch has a few changes over the prototype:
- Rear vent area has been increased
- Larger motherboard cutout
- 2x 2.5 inch drive mounts at front of case added
- Mounting point for Meanwell RPS-200-12 added at front of case
- Vented side panel added as standard
- Inside fan mount design changed slightly
are you going to sell versions with the alternative front (visible fan grill)?
Here's a better Idea.
A magnetic modular grill!
Or use the ball stud thing that the cerberus uses?
I would like too, but we'll have to see how this first small batch goes. The perforated pattern took 75% of the votes on my survey. How many of those 25% would only buy it based on the wire fan grille style? Personally, as time has progressed I've become less fond of the fan grille look and grown to like the perforated pattern more. That's just me though.
Is anyone aware of an 80mm wire grille that's flat? Most have an offset built into them.
