I received confirmation from my manufacturer that I can do whatever with the blemished covers. My new parts shipped today (earlier than expected), so I should see them Monday or Tuesday.
Hey Mr Lone. Just a quick post to say thanks. Great little case you made here. Really like everything about it (One suggestion for improvement). I got mine earlier this week and just finished the build. I didn't take pictures along the way so no internal photos, just the finished build sitting on my desk. But that isn't a big loss, I didn't really do anything other than what was intended on the inside.
I was planning to do a 65W Ryzen build. Either the 3600 or 3700x. But when I went to Microcenter to pick one up, they had a fresh shipment of the new Intel 10th gen stuff so I figured that would be fun to check out. I wound up going with the only 65W new Intel CPU they had. The i5 10400. 6 threads, 12 cores, 4.3ghz . Plenty of power for the use of this machine. Mostly general office and web browsing stuff with occasional Solidworks and Fusion 360 CAD modeling and some light gaming very occasionally.
Here are the specs: of the build:
A few quick comments. I know its not a popular choice right now, but so far I like the 10400 chip. Runs super cool and quiet and performs as good as my old 8700K, except alot cooler. With this setup in aida64 it never goes over 61 degrees no matter what I do. The CPU never gets hot, no matter what I do. Even hammering both the GPU and CPU at the same time and making the inside of the case really hot. Lots of headroom, I probably can go up to one of the K chips and be fine if I ever want too.
- Intel i5 10400 (65W, 6 core, 12 thread)
- Noctua NH-L12S
- Gigabayte Z490 AORUS ULTRA ITX ( I know, Z series isn't needed on the locked chip but its what they had and I wanted to try the new Intel for myself. I wasn't on any kind of tight budget and this leaves me headroom if I want to get one of the K chips in the future)
- GIGABYTE GeForce GTX 1650 4GB GDDR6 Low Profile (The just released updated version with DDR6 and 4 video outs.1 x Dual-link DVI-D 2 x HDMI 2.0b 1 x DisplayPort 1.4 )
- 2TB Intel 660P nvme
- 16GB Corsair LPX DDR4 3200 C16
- HDPlex 200w DC-ATX
- Dell New Slim Style 240W AC Adapter
- (2) 80mm Arctic P8 PWM fans (crazy long stock wires. Had to shorten them for my own sanity)
The GPU on the other hand.... Its a little fireball. Crazy high temps. Bumping up as high as 89 degrees running furmark with fans at 100%. (I will say the fans aren't as loud as I expected those little things to be, so that was a pleasant surprise. Which brings me to the only suggestion I would make for changes on this case. Please add more bottom ventilation. The holes that are there really only allow one of the gpu fans to breath. I personally would just cover the bottom panel in holes like you have, just 3X as many of them across the whole bottom of the case. I wound up linking the front fans to the mother board temp sensor that is right next to the GPU so as it heats up the front fans ramp up. I am considering a hole saw to put a clear open hole right below each of the fans, but haven't gone there yet. Anyone else run into this issue and have a good suggestion for a fix?
For now what I did to solve the GPU temps is to install MSI afterburner and knock the max power down to 90%. Even at 90% I was still able to bump the core clock up by 75mhz and the memory by 500mhz and its all still stable with no issues. Doing this doesn't seem to hurt the performance, but it knocks the max temp down to 73C. Still hot, but much more reasonable. As a matter of fact it actually increased the score on a few benchmarks I tried. The high temps were keeping the core clocks lower.
Had a good time building in your case and it fits perfectly in my little work space!
Thanks! Ijust got them on Amazon.Jhautz - I like those USB extension cables. Who makes them & where can I buy them? Thanks. Great looking setup!
Amazon Germany shipped to USA. Amazon made it super easy and shipping was like 5 euro. I think with conversion it was $160 USD. There is a website you can plug in a product and it will search all the local Amazon sites for the best price.smitty2k1,
Where did you buy the Asus 1650 LP? All I've been able to find online at US retailers is MSI or Gigabyte & Zotac whch never seems to be in stock anywhere. Thanks.
Received the custom Schuko to WEIPU connector for the HDPLEX AC-DC brick from Solidstrands today. Really looking forward to building in the case without having to grind a part of the PCI slots away ?
Looks greatt. Can you share the details of your order for those wanna order the same? Also the cost please.![]()
APU Setup | | |
Gigabyte B550I AORUS Pro AX | £188.47 | Ebuyer |
Micron MTA18ADF4G72AZ-2G6B2 32GB 1RX4 2666 x2 | £435.98 | LambaTek |
Alpenföhn Black Ridge | £43.53 | Overclockers UK |
Noctua NF-A12x15 PWM x2 | £43.98 | Amazon UK |
HDPLEX 200W AC-DC | £51.49 | HDPLEX |
AMD Ryzen 4700G | £300.00 | Estimate |
| £1,063.45 | About ($1332.15) |
