Here's a photo of the G-Unique Arch Daemon DC-ATX from my July batch. This batch I opted for a modular SATA connector right on the PCB.
In case it's of interest, a customer from France suggested changing the thermal paste on your GTX 1650. He said normally there's no warranty sticker on the screws, so you can can take off the heatsink without voiding the warranty. Anyway, just a thought.
Poor Cooling Fixed GTX 1650
Solved the termal solution for my new GIGABYTE GeForce GTX 1650 DirectX 12 GV-N1656OC-4GL the card has been running hot since i got it in the mail Tuesday 05-19-2020 on stock settings as this is in a Low Profile Chassis but found out why it was running hot the stock thermal paste was non-existent...linustechtips.com
Excellent note! I have not taken the card apart, but with what you just showed me I will probably do that this weekend! Certainly can't hurt anything.
Good lookin out!
FYI, the new top/left covers have the GPU vent extended a little to match up with the CPU vent. Blemished covers are available on the website.
Here's a photo of the G-Unique Arch Daemon DC-ATX from my July batch. This batch I opted for a modular connector right on the PCB for the SATA cable.
Nice, is this meant to be used with the Mini-box 192W AC-DC?
As a side note, I did play with taking the fans and shroud off of the card and using larger 80mm fans under the bare heatsink to see if that would help even more, but in general it was within only a degree or 2 and was actually louder because the fans were so close to the case vent holes it created turbulence and a lot of fan noise. Once I got the GPU cooler mounting issue sorted out the stock fans and shroud work just fine and the sound is very reasonable.
Just a quick update on the increased venting and the GPU repasting.
I replaced the side panel with the larger vent version and it did help the GPU temps by a few degrees. Not massive, but certainly a worthwhile update. I saw a drop of 2-3 degrees on the GPU. I really appreciate you making this revision. A definite improvement.
As for the GPU repaste you pointed me to. I pulled the heatsink and cooler off the card and put on some new high quality paste and actually saw the temps get worse by 10+ degrees. I had to do some investigation, but what I essentially concluded was that the cooler is poorly designed and does not put enough pressure on the GPU die so the thermal transfer is poor. I ended up adding some 1mm thick plastic washers under the 4 screws that hold the heatsink onto the GPU board effectively increasing the amount of tension on the springs around the screws and that seems to be the solve on this card.
- Stock GPU power, clock and fan settings. No card mods and factory thermal paste. Card ran around 85 degrees and the clock speeds dropped down to around 1500mhz. Box calls for 1620mhz boost speeds.
- Replacing the thermal paste with Arctic MX-4 and keeping all settings stock. RAISED the temps and lowered the clock speed.. Temps jumped well into the mid 90's and gpu clock speeds dropped to only 1200mhz. Bad, Bad, Bad.
- Keeping everything the same except adding 1mm thick plastic washers under the 4 heatsink mounting screws fixed it all. Temps are down to around 70C. And clock speeds sit right at or a little over the boost speeds listed on the box for basically as long as I want to run it at full blast on furmark.
Appreciate the help in sorting this all out. Still loving this little case and even more now with the increased GPU venting.
Thanks again and keep up the good work!
Hi thanks for letting us know about your experience with the 80mm fan. I was thinking of doing that. But if its louder, I won't take the plundge. What are your thoughts on 2 small noctua 40mm fans fixed to the heatsink with some cableties? They should be quieter and push more air than the stock fans on the gigabyte.
I am actually tempted to try it out on my card (Asus gtx 1650). But its roughly 30€ on top of an already somewhat overpriced 1650 LP.
Hey Lone:
Did you sell out of the blemished case tops?
So I just ordered a Lone L5 with G-unique , I'm planning a music workstation build, so a R9 3900x 32GB ram 4TB nvme and a Radeon Pro WX 3200 lol, it can do multiple 4k (more than I need) and it's 1 slot, no external power, so what I'm getting on about is I've got multiple ideas on how to power it, right now, I'm on option 1.
Side note, Also I'm going with the asrock x570 with thunderbolt 3, and a Id cooling IS 60 with a 25mm Noctua fan, but you might be saying, that won't fit, there are too many wonky vrm and chipset heatsinks, and you would normally be right, but some few choice purchases of alphacool copper heatsinks for VRMs and a new chip's heatsink with Noctua 40*10 fan upgrade, should fit and Arctic Silver thermal Adhesive to hold it all together,so just to show, not afraid of modding the heck out of it lol
1. A 330w Dell block and waiting on a Pico box X300, so gonna find a way to put that in there, planning on right beside the GPU, hence why I went with 1 slot.
So I've got a few backup options / ideas to power it if that fails too.
2. 300 w 12 v power supply for LED lights with the included G-unique atx
3. This is the full send option, it's a military style 32 pin circular bayonet connector lol, would just have to check with the manufacturer that it can handle the Amperage, they're rated for between 7.5-13 amps, but that's at 600v so as long as it's not 600v, I should be fine, but like I said, will have to check with the manufacturers to confirm my theory, and with this option, I'll just Wire up a full ATX (probably A SFF one or flex) power supply in a box with a cable hanging out of it and just be done with power limitations lol
I tried this also, and I wasn't super impressed either. An 80mm fan is much larger than the GPU heatsink. Noctua 40x10mm would be interesting to try. I've posted it before, but I've also made my own "low noise adapters" for the GPU fans. Combined with a front 80mm case fan, and lower fan speeds you might be okay. I haven't tested this in the L5 though, and don't have easy access to a GPU with fans at the moment.
Hi Lone, just wanted to get back to you. I got an amazon warehouse deal for 3 40mm Noctuas. Got around to trying them out today. But sadly its not the best. It didnt really quiet down my system. I might make a more sophisticated fan shroud and try out some different fan curves. Right now I can't say its worth the 30 bucks. The asus card is already pretty quiet with a custom fan curve.
I will finish up my cable managment and try a little more scientific approach to the 40mm fan testing. AAAnnd then I will get around to snapping a pic of the build and post it here![]()
My experience with GPU fans has been similarly dismal.
At some point I'll get around to a longer post, but for those contemplating 40mm or 80mm fans, I've tested a few combinations now and have a few notes which I hope you find helpful.
Note: these are pointedly not scientific tests. They are just rough ideas of what you can expect, from someone who seems to have less and less time to enjoy this niche hobby.
With an Asus GTX 1650 LP (undervolted to 0.850v @ 1700mhz), and a Noctua NF-A8 intake fan on the chassis fixed at 1000rpm. All load tests in Unigine Valley. In order of preference:
These options are all deficient in one way or another. If I can tame the Cooler Master fans I'll use them -- otherwise the stock fan and shroud seem to present the best compromise between noise and temperature control.
Cookermaster
My L5 build...
MOBO: Gigabyte Aorus x570i Pro Wifi
CPU: Ryzen 5 3600
CPU Cooler: Scythe Big Shuriken 3
GPU: Gigabyte 1650 LP GDDR6
STORAGE: 1TB Intel 660P NVME SSD
RAM: 32GB G.Skill RGB 3600mhz
PSU: G-Unique Arch Daemon DC-ATX
FANS: Noctua Chromax NF-A12x15 and 2x NF-A8
Thanks for looking!
