Lian Li/DAN A3-mATX
bellerophon
Hey may I ask, I got this Card:
with this Block:
it is said to be totally 160mm from terminal to PCIE connection. Is there gonna be any luck with it to fit in this case ? 😅😅
I have the same GPU block thats roughly close to yours which is 155mm in height. Hopefully we could a 3d file to mock up it 😂
dondan
DAN Cases
1,871
7,946
Here is a concept for the new A3 i am working on. The final case will be between 22 and 25L.
Sry for the bad quality on the mesh parts. Its a screenshot out of solid works. Also the feets arent final.
shangor
Looks inspired by Fractal Design North (a good thing).
It probably wasn't easy giving up <20L. I'm sure it's for better airflow (eg bottom/top fans).
This could be the smallest matx case with few compromises, compared to the now very popular Asus AP201.
The only thing is that I expected it to be on sale sometime in March/April. That doesn't seem very likely now.
bellerophon
Will there be 3D file for this where we can mockup some parts :) kinda like what ssupd meshilicious provided.
alfdpw
21
I liked the original feet much more. They were very aesthetically pleasing.
itsmebob
I was eagerly awaiting the sub 20l a3-matx case to succeed ones like Sama IM01 for the longest time. 22-25l can't be considered sff, completely strips away its original charm imo.
dondan
DAN Cases
1,871
7,946
I understad your critic, but in this project i do not make the requirements for supported hardware.
oynasun
Hi @dondan will this support ASRock's GENOAD8UD-2T/X550 for EPYC 9004?
alldaybig
Looks better than the original design! I love it! No worries about the slightly larger size than the og design, I think it needs to be more feature full than small.
alldaybig
DriverDaily
I like the extra size and the front of the case,
But I don't love the mesh. Also, I wish the seam between the side and top/bottom panles was on the top and bottom and not the sides.
