My Kimera Industries / Sliger Cerberus X 7980XE 1080Ti SLI Workstation.
General Specifications and 24/7 Overclocks.
Intel Core i9-7980XE Skylake X 18-Core Processor. Overclocked to 4.4GHz (8 AVX Offset) at 1.20V -75mV Adaptive.
HyperX Fury 64GB (4 x 16GB) DDR4 2400MHz Memory. Overclocked to 3466MHz at 1.40V
SLI NVIDIA GeForce GTX 1080 Ti Founders Edition 11GB. Undervolted to 1800MHz at 850mV.
Test fitment of the beQuiet Silent Loop 240mm AIO with Seasonic Prime Ultra 1300W Platinum PSU. Easily clears the CPU block, and is a 1mm from the top of the fittings and tubing.
This is the only AIO with a nickel plated block you can use with an ATX power supply mounted above the motherboard.
I specifically needed it to be nickel plated to prevent degradation of the block when using liquid metal with Der8auer’s Direct Die Frame.
Post delid of my 7980XE. All old silicon was removed, the PCB was polished clean with paper towel, and the SMDs were coated with liquid electrical tape.
Everything installed, including the Bluetooth/Wifi M2 card, as the EVGA X299 Dark does not come with it onboard or preinstalled.
Cable and tubing management. There is around 1-2mm clearance between the front intake fans and the 1080 Tis. I have also managed to make enough room between the power supply and front intake to mount four 2.5 inch HDDs off the side bracket, which will be perfect for a RAID10 array.
Close up of the cable and tubing management. I have made an order for custom length braided cables. However, I am unsure if I will use them at this stage.
You can also see that the top slim 120mm exhaust is very close to the power supply and motherboard. There is about 1mm of clearance. I had to remove the clips on the 8-Pin EPS connectors as they were in the path of the fan blades.
Side hinged bracket installed. Highly recommend getting it if you order a Cerberus case, regardless of whether or not you plan on mounting anything on it. It adds rigidity to the case, which i felt was necessary with this much hardware installed.
Front and side panel removed. Motherboard cutout was perfect for me to install Der8auer’s Direct Die Frame. I did however have to loosen the motherboard screws slightly to get enough clearance between the motherboard and case.
Two 140mm Noctua Industrial fans mounted in the bottom. The feet had to be removed to mount the fans as they were covering the outer corners.
Black machined handle and perforated top panel. The handle is of high quality and is strong enough to hold the entire weight of the PC. The handle mount also allows for a 120mm fan to be installed.
I will be adding four 1TB SSDs in RAID10, and a 970 Pro 512MB. I’ve ordered the chrome feet, chrome handle, and a walnut top panel. I plan on modifying the top panel with perforated holes under the handle so I can still have a 120mm slim fan mounted there to keep the VRM cool.
Hardware, Materials, and Specifications. Prices are in AUD.
1 Intel Core i9-7980XE Skylake X 18-Core 2.6 GHz LGA 2066 165W BX80673I97980X Desktop Processor $2732.07
1 EVGA X299 DARK, 151-SX-E299-KR, LGA 2066, Intel X299, SATA 6Gb/s, USB 3.1, USB 3.0, EATX, Intel Motherboard $749
1 HyperX Fury 64GB (4 x 16GB) DDR4 2400MHz DRAM (Desktop Memory) CL15 1.2V Black DIMM (288-pin) HX424C15FBK4/64 (Intel XMP, AMD Ryzen) $1059.98
1 Seasonic PRIME 1300W 80+ Platinum Power Supply, Full Modular, 135mm FDB Fan w/Hybrid Fan Control, ATX12V & EPS12V, Power On Self Tester, 12 yr Warranty, SSR-1300PD $419
1 SAMSUNG 970 EVO M.2 2280 250GB PCIe Gen3. X4, NVMe 1.3 64L V-NAND 3-bit MLC Internal Solid State Drive (SSD) MZ-V7E250BW $99
4 SAMSUNG 850 PRO 2.5" 1TB SATA III 3D NAND Internal Solid State Drive (SSD) MZ-7KE1T0BW $1276
1 SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe 1.3 64L V-NAND 2-bit MLC Internal Solid State Drive (SSD) MZ-V7P512BW $229
2 Noctua NF-A14 iPPC-3000 PWM, 140mm PWM,AAO Frame Technology and SSO2 Bearing Fan $77.9
2 Noctua NF-F12-3000 PWM 120mm 3000 RPM 43.5 dBA 4-pin SSO2 $69.74
1 der8auer Skylake-X Direct Die Frame $119
1 der8auer Delid Die Mate X $149
2 NVIDIA 900-1G611-2550-000 GeForce GTX 1080 Ti Founders Edition DirectX 12 11GB 352-Bit GDDR5X PCI Express 3.0 x16 HDCP Ready SLI Support Video Card $2198
1 NVIDIA GeForce GTX SLI HB Bridge, 4-Slot 900-12232-2500-000 $40
1 Intel Dual Band Wireless-AC 8265 Desktop Kit 802.11ac 2x2 WiFi Bluetooth $35
1 be quiet! Silent Loop 240mm Liquid CPU Cooler $169
1 KIC11X Window + Vented, Right Panel Vented, Machined Chrome Handle, Machined Chrome Feet, Walnut Top Panel $502.10
1 Thermal Grizzly Conductonaut Thermal Compound 5g $45
1 Liquid Electrical Tape/Thread Locker - Black $16.95
