Power Supply HDPlex 400W AC-DC Adapter
sparklepony
71
You know it's going to ship friday at 17:55, then get stuck in a warehouse over the weekend and arrive at your place friday next week when you are not home so you cannot pick it up before monday next week again LOL
Reactions: cornut
rook
74
78
Got mine up and running but I have complaints already !!
The thing is supplied with 4 different types of screws, a fan and a bunch of other stuff. There's no list of what each screw is for & the fan mounting holes are not threaded. I feel like none of the screws work in the fan mounting holes either. I thought about jamming the white n̶y̶l̶o̶n rubber screws in there, if they'd go, but those don't fit down into the fan shroud. Anyone else had success?
Edit: Read directly from the HDPlex website, "M3 Rubber screws for fan mounting". Time to mash 'em in there.
robbee
890
1,408
I don't know how it works with the HDPlex, but pc cases also don't have threaded fan holes. Can't you thread into the plastic of the fan?
19NinetySix
53
How long after a power cut is it safe to touch the case? (When ungrounded) I had one last night and it got me thinking.. since I'm considering just using the C8 rather then mod the case
Choidebu
"Banned"
Aug 16, 2017
1,198
1,205
Perth
Nonsense. You should only worry about this if you use it with the case open. Let the certifications worry about that for you.
sparklepony
71
The case is kind of open at all times. I wouldn't want my kids fingers near this case. That said I also wouldn't worry about it.
HYPERTiZ
87
30
Australia
My order #21444 has shipped!
I think mine shipped 11th March - im guessing its stuck at Shenzhen International Mail Exchange Bureau or something - i'm extremely patient for some reason.
On a side note -
I did notice Josh in a video removed the housing from the HDPLEX to enable the GPU connector to sit with enough room to install - without needing to do anything drastic and keep it stock? Is that safe lol.. I mean it isnt like we'd like touch it internally but thatch a pretty neat solution
Wish more GPUs had horizontal connectors like the nano specifically for itx sizes though where clearance would never be an issue.
LFO
100
23
Belgium
I contacted Larry yesterday, and the big batch is on it's way to Germany... and most likely arrived today as I just noticed my status is changed from on hold to Processing!!!
So fingers crossed !!!
Cheers!
t_sale
Cheers!
Do you know how many are arriving in this batch and what order number do you have?
t_sale
No I don't know, more than enough I assume :-), I'm 414
Thanks mate! I certainly hope you're right. Such an exciting time! I'm very appreciative of Larry's commitment to the SFF community and what an incredible product he's made. So glad he was able to bring it to market.
Reactions: Kmpkt
