And so here is next week!!!
And another week ends. Still nothing.
Playing division 2 on a MacBook Pro in 720p everything on low/off in 25 FPS suuuuuucks
Thanks for reminding me of division 2, I was given a free code with my Ryzen 7 2700X CPU to download the game :-) but no pewter to play!!!
Right now I'm quite busy anyway trying to figure out what materials to use as a DIY SSD/HDD bracket so I can stack 2x2 2.5" 7mm drives on top of each other. (yes 4 drives in a S4mini)
All purpose brackets seems to be minimum 25mm but I only have 15ish available and I'm not sure if it's safe that the drives are touching each other or the middle of an aluminum T profile...
Touching drives should be fine as there shouldn't be any charge between them.
Depending on the weights involved and the amount that you move your case you may be able to use a double sided thermal adhesive like this: https://www.amazon.com/dp/B019MUTF4A/?tag=theminutiae-20
Or you could 3d print your own brackets similar to this: https://www.thingiverse.com/thing:3079625
It would probably have to be smaller but if you wanted to leave a 1mm gap and your drives are 7mm then it should be ok.
I got an email from Larry stating that the second batch should be shipping early next week then received a USPS label created notification. Order no. = 21874
This is what I did before:
Eventually went away with it, because I made it with 2 mm space between them and it bulges behind my gpu and touching the side panel (S4M-C). If it was 1 mm it would've been fine.
I can't remember why I didn't just use a straight bracket, might feared the bracket touching the gpu and shorted some leads...
Got my tiny AC-DC baby on Saturday, couldn't be happy more with it!
Already sanded and tested. Feels like brick doesn't give a crap about hot temperature and works flawlessly even with 1080 mini dumping enormously hot air straight into PSU.
Dynamo 360 was overheat-resetting until I flipped it upside down. That way large bottom heatsink protects the unit from hot air. Now when the system is stable I can finally start cutting and sleeving cables.
Tomorrow would be a year since the thread has started and I can say the wait was worth it. Unit's stability is great, the fan is very silent and the minor coil whine could only be heard when putting an ear closely to the unit.
Fantastic job, Larry!
I haven't disassembled PSU, just unscrewed side screws, stuffed cottonwool in every possible whole to avoid dust getting into the circuit board and started sanding it with a grinding wheel. I had to grind 1mm from each side to fit it in the front of case. A monotonous process I must say, took me more than 2 hours.I was thinking about doing the same thing, with the rtx 2070 (as in Josh’s custom build). Did you file down the HDPLEX to fit? If so, how? Was planning on filing mines down, but was looking at the block last night and realized I’d probably have to disassemble the sides first.
my suggestion would be removing your SkyReach's flange, so that a HDPLEX AC-DC fits in the front, instead of this sanding technique.
a brickless build like that, was shown in Josh's youtube video.
By "removing" to you mean sawing off a piece of inner chassis?
i mean cutting it off.
after watching Josh's RTX2070 youtube video where it has been done, my conclusion is that this piece is like your wisdom teeth, appendix, or tonsils.
yes, i know that they originally come with your body, but what purpose do they serve ?
and why not just remove them ?
And here are some words from Josh himself on the mod. (timecoded)
while i highly respect Josh, the great thing is that i have free speech rights, to respectfully disagree with him.
many of Josh's opinions are not independently objective, because he makes the SkyReach, & admits himself that he thinks it needs absolutely no improvement.
Well, I'm glad I'm the one who got on the 348mm train since Skyreach JUST fits my rigid backpackwhile i highly respect Josh, the great thing is that i have free speech rights, to respectfully disagree with him.
but note that in this same series of youtube videos, he states considering a SkyReach length increase, from 348mm to 363mm.
even with cutting of flange you would need to use grinder to fit PSU in the case.
