Power Supply HDPlex 400W AC-DC Adapter
Reldey
387
405
So, from some various forum posts (@Josh | NFC), it has been confirmed that a 400 watt AC/DC which can fit inside a Skyreach 4 Mini is currently in development by HDPlex. Not sure if making a forum thread about it is appropriate, but seeing as how I imagine a lot of people in the community are excited about this, having a consolidated place to post news about it seems worthwhile.
EDIT 1: From @Kmpkt
Specifications and drawings are up on the HDPlex website now!
https://www.hdplex.com/hdplex-internal-400w-ac-dc-adapter-with-active-pfc-and-19vdc-output.html
Length reduced to 180.4mm
Width increased to 58mm (o_O)
Height remains at 40mm
EDIT 2: Live stream from @Josh | NFC with ACDC brick in hand.
EDIT 3: Preorders now live!
EDIT 4:
Preorders are shipping now! Also, @Josh | NFC uploaded one of the coolest builds with this thing yesterday in a stream. Very little modding is needed to fit an RTX 2060 into a Skyreach 4 Mini, brickless. Check it out here:
Jello
375
161
What kind of hardware could this adapter comfortably power? Would this be enough for a GTX1070 and a 65W CPU?
Reactions: rosinbole
Naavjames
37
34
Does this mean we can finally ditch the Dell 330w brick?
I hope it fits with a zotac 1080 mini inside the Skyreach 4 mini case.
@kpm
I read on another thread somewhere...
@Kmpkt Mentioned it would accommodate the gigabyte 1080 but not the Zotac 1080 :-/
Ditch that dell brick, brickless ftw
Jello
375
161
I wonder what kind of GPU clearance this will have if Josh is correct about it fitting in a S4M.
KMPKT
3,382
5,934
With respect to GPU, the new AC-DC unit should have the same height and so will allow you to either use a reference height GPU (111.15mm) up to 215mm) or alternatively an overheight GPU of up to 170mm in length. If you can get a reference height GPU that is 170mm or less then you can use an AC-DC unit on either the bottom of the case or along the inside front panel. My secret hope is that the Vega Nano will be 170mm long and 111.5mm high and allow for two AC-DC units (400W + 160W) to be combo'd in the S4M :)
Bphornett
Apr 10, 2018
Would this be designed to work in coordination with the HDPlex or Dynamo type DC-ATX units? Or will it be everything in one unit?
Reldey
387
405
@Kmpkt thanks for the info so far, I may have jumped the gun in making the thread, but I appreciate it. Looking forward to it, will definitely make my next build with this when it comes out.
McTeags
130
148
While you’re replying to questions I might as well ask one too :)
@Kmpkt Do you you have any other comments on the dimensions of the PSU outside of the height of the unit being around the same?
