Why does the website shows them as "sold out" rather than "available on xxx" ? https://www.hdplex.com/hdplex-internal-400w-ac-dc-adapter-with-active-pfc-and-19vdc-output.html
Coding simplicity.Why does the website shows them as "sold out" rather than "available on xxx" ? https://www.hdplex.com/hdplex-internal-400w-ac-dc-adapter-with-active-pfc-and-19vdc-output.html
I have all the parts besides the hdplex 400w (once it’s released I can do the measurements and buy the gpu to build a brickless S4M.)
Can someone already confirm now if I can fit the gigabyte 1070 mini brickless with this? I don’t know where to measure from and to, to get the max card width to fit it.
I pretty much just assume it will fit, but Inam aware I need to mod the pin connector to make this work (if it works)
Hello guys
I try to build new pc with HDPLEX 400w ac-dc.
dose it derate the power in 100Vac area?
For example, Meanwell EPP400 is derating the power to 85-90% in 100Vac area.
ETA for mid - Sep.
The delay was caused by another efficiency improvement cycle.
Guess another two weeks wont hurt![]()
No, zotac 1080TI is an oversized card. Only reference height cards would leave space for 400w brick at the bottom of the case.So, after carefully reading everything thus far and being slightly confused by some of the comments, will we be able to make a brickless S4 Mini build with a 1080 ti and this baby inside?
Would the EVGA gaming series 1060 work, even though it's just slightly past the bracket?(snip) Only reference height cards would leave space for 400w brick at the bottom of the case.
Are any of the GTX Mini series a true "ITX length" card?
Only reference cards will work with the PSU on the bottom of the case as even with those the tolerances are rather tight. That being said, if you use a true ITX length card, the 400W AC-DC can fit comfortably on the front of the case and you can put a Dynamo 360 on the bottom of the case.
